C7 Corvette 2014-2016 LT1 LT4 Dry Sump Harmonic Balancer Kit @ RPI Designs
Platinum Supporting Vendor
2014-2016 C7 Corvette LT1 LT4 Dry Sump Harmonic Balancer Kit
Why You Need a Harmonic Damper?
The crankshaft buried deep inside the engine in your car isn’t a solid, immovable hunk of steel or iron. The crank twists and bends relative to the loads placed upon it by the respective pistons and rods on each throw. General Motor’s research has shown there is considerable crankshaft deflection in a race-prepped engine spinning at 8,000 rpm.
There is also resonance to consider. This occurs when the torque an engine makes on each combustion cycle “syncs” with the crankshaft’s natural vibration frequency. Without a proper harmonic damper to dissipate the torsional vibration caused by resonance and deflection, certain crank failure and other damage will occur, including:
◾Worn main bearings
◾Misaligned main bearing caps
◾Loose connecting rod bolts
◾Shortened valve spring life
◾Broken oil pump drive shaft
◾Stretched or broken timing chain
◾Scattered ignition timing
◾Loose flywheel/flexplate bolts
◾Fractured flywheel
◾Difficulty shifting gears with a manual transmission
This is a direct replacement harmonic balancer for the C7 Corvette LT1 or LT4 with the dry sump oil system.
Includes:
LT1/LT4 Dry Sump Damper
5/16 - 18 x 1 Flathead Torx Screw
3/4 - 16 x 1-1/4 12 Point Bolt
Shell Assembly
GM OEM Crank Bolt
Item # L220660114
Website Link : http://www.rpidesigns.com/shop/item....-balancer-kit/
◾Worn main bearings
◾Fractured flywheel
Includes:
Shell Assembly
GM OEM Crank Bolt
Item # L220660114
__________________
