Electronic limited slip differential
I have been looking at the display for eLSD. I thought it would be a percent one rear wheel is rotating compared to the other . However sometimes when going straight down the road it is measuring 15% The percent seems unrelated to turning which would seem to increase slip. The readout appears more related to speed. Anyone know what this is a actually measuring? There is a bar at the bottom that seems a little more instantaneous.
Popular Reply
04-20-2016, 07:49 PM
2017 C7 of the Year Finalist
It measures the percentage/amount of clutch disengagement. When it reads 0% left and right axles are locked 1 to 1. In a tight corner you will see a higher number for the amount of clutch disengagement.
As explained and/or understood at Corvette Owners School.
The following 6 users liked this post by jaden61:
63Corvette (12-27-2016),
JWingo (04-22-2016),
NSC5 (04-20-2016),
SBC_and_a_stick (04-20-2016),
tail_lights (04-21-2016),
and 1 others liked this post.
That's the way I understand it but when I watch the gauge it doesn't seem to go up going around the corner and sometimes reads higher going straight ahead then when I get into a corner. Maybe it averages it over time?
I just returned from Spring Mountain and I asked what this was for because as an engineer it made no sense to me. They said that they asked a GM engineer so they could explain it to the class. He told them that you should ignore it and it should never have been put into the car. So the technical answer is Ignore.
The following 2 users liked this post by VetterFlyer:
Mike Mercury (07-24-2017)
tp10 (04-21-2016)
Every once in a while the software geeks sneak one past the Chief Engineer.
Corvette fan
Good information.
For some reason I thought I saw something here that referred to a software reflash to get it working correctly.
Not one of my go-to gauges.
Glad I came across this thread. Mine reads 7-10% most of time when driving in a straight line. Not sure why the clutch would need to disengage under these conditions. But I'll just ignore.
Received 2,379 Likes
you don't want a locked diff in 99% of cases other than a fully controlled hard drag style launch.
JMVett (12-11-2018)
So mine says 0% on the left and 30% on the right no matter what I do???
I give.
Jim
I give.
Jim
Painrace (06-24-2016)
After riding around watching the number not changing hardly at all from straight down the road to a sharp turn it must be a measure of the line pressure to the clutches not the actual wheel to wheel speed differential. I was just driving around getting my 500 miles. Maybe if you are hard on it the numbers change but for now I won't be putting that screen up again.
