DIY Header install
DIY Header install
For anyone who might be interested, I have started a thread on the Tech forum on my journey to install ARH mid-lengths on my Z06. Please, if you have any tips, suggestions, or experiences to share feel free to do so.
3 Z06ZR1 (05-14-2016)
It will take some time so start early and do no get frustrated. Disconnect battery, then open the hood and remove the passenger side fuse box assembly thing completely. This will help tremendously with the install. You will also have to remove the starter plate from under the car for clearance and drain the oil and remove the dry sump oil lines from under the car on the passenger side. This is a good time to change your oil.
Once OEM headers are almost unbolted make sure you take of the bottom section of the headers off, otherwise they will NEVER come out through that confined space.
These are a few tips I have. Good luck. If you have any questions feel free to ask.
Eddie
C7 x 2 (05-14-2016)
I'm letting Wong's performance put on and tune my ARH longtubes!
C7 x 2 (05-14-2016)
