MS109 VP Fuel
MS109 VP Fuel
For those of you that have ran VP MS109 Unleaded fuel, how did you mix it? Any idea would the ratio would need to be to prevent any knock retard? I run Shell 93 pretty much all of the time.
I have a standing mile event coming up and I wanted to prevent knock retard but don't want to mix anymore than necessary.
Thanks in advance!
Thanks in advance!
I buy the 55 gal drums, and mix about 2gal per tank to stave off detonation. I typically don't run it on every tank, so it's important if you are running an event to make sure your on the high octane table. Only time, reflash, or power disconnect will get you back to those tables if you were just running crap for fuel.
