Track rated brake fluid
I am getting ready to upgrade the brake fluid for track use. The manufacture's recommendation is to use a fluid with at least 534 degrees Fahrenheit dry boiling point. It also says to avoid silicone or DOT 5 brake fluids. Castrol SRF is a DOT 4 fluid but is a silicon ester type fluid. Is silicon ester considered a silicone? Is this permissible in the C7 Z06?
The Wilwood looks like a very good value.
Received 8,928 Likes
Which manufacturer recommends a dry boiling point over 534 deg? Anything I see from GM just states DOT4 which is spec'd at more than 446 degrees. Most have less than a 500 deg dry boiling point.
I like the Wilwood fluid. Both the 570 and 600 Plus.
Bill
Bill
As has been said, SRF is not a "silicone based" fluid, and as you mentioned it has "silicon (no "e" in the Castrol spelling) ester" in the blend. Here's some info from the Castrol site:
Castrol SRF Racing Brake Fluid
Castrol SRF is the ultimate racing brake fluid. Its unique silicon ester technology absorbs less water than conventional glycol ether fluids and prevents the fluid's high-temperature performance from deteriorating. It's (sic) high boiling point, ability to withstand extreme temperatures and superior resistance to the effects of absorbed water have established Castrol SRF Brake Fluid as the world's premier fluid for the hydraulic brakes used in all forms of motorsport and racing.
What the "base" of SRF is I dunno!? The base of most DOT 3, 4, and 5.1 fluids is glycol ether, and the DOT 4 and 5.1 fluids usually have borate esters added. Maybe SRF uses a base of glycol ether but adds silicon ester instead of borate ester - hoonose?Castrol SRF is the ultimate racing brake fluid. Its unique silicon ester technology absorbs less water than conventional glycol ether fluids and prevents the fluid's high-temperature performance from deteriorating. It's (sic) high boiling point, ability to withstand extreme temperatures and superior resistance to the effects of absorbed water have established Castrol SRF Brake Fluid as the world's premier fluid for the hydraulic brakes used in all forms of motorsport and racing.
In that quote above from the Castrol site it does use the wording: "absorbs less water than conventional glycol ether fluids", and I suspect that it does use glycol ether as the base, but uses the silicon ester that makes it a "unique...technology".
Let me add that I believe some European fluids are designated 5.1, and also use the terminologies of DOT 4 Plus or Super DOT 4.
I believe our GM DOT 4 clutch fluid is a relabeled Pentosin product that they call a "Super DOT 4", but is just DOT 4 when sold here in the U.S.:
SUPER DOT4
Size: 0.25 liter (0.26 quart), Part# 1204112
0.5 liter (0.53 quart), Part# 1204114
1 liter (1.06 quarts), Part# 1204116
5 liters (1.32 US gallons), Part# 1204204
Color: Yellow & Clear
Boiling Point > 265°C (>509°F)
Wet Boiling Point > 165°C (>329°F)
Take a look at this StopTech White Paper Tech Bulletin:
http://www.stoptech.com/technical-su...rs/brake-fluid
In there you can read that DOT 3 fluids apparently usually are a glycol ether base, but "not because they are required to be". Then DOT 4 and 5.1 fluids start to add borate esters to the mix, and maybe that's where Castrol uses the silicon ester instead.
Bottom line - you can just flush Castrol SRF into your C7 brake system just as you would if flushing in any other DOT 4 fluid.
The SRF is not very hygroscopic. Its wet boiling point is higher than some fluids dry boiling point. Im a big fan of the Endless fluid as well as the SRF.
