Rippling leather on center armrest
I noticed after I got home from a trip last weekend that there is about a 4 by 6 inch area where my elbow rests in the middle arm rest that the leather has a very noticeable rippling effect where my elbow rests. Is this an issue you guys have run into? Is this a factory warranty repairable claim item?
I've seen this complaint before. One fix was leaving the car in the sun on a hot day for a while. It's an easy replacement part either with OEM or aftermarket options. But I'd definitely run it past the dealer first.
Received 2,682 Likes
2018 C5 of Year Finalist
I wonder if it's a leather issue or whether the factory should have used better memory foam underneath. If you work with the dealer, you may get a replacement and that replacement may have the same problem. Perhaps a trip to a custom auto upholsterer may give better answers.
I also wonder if it's Mulan vs. Napa leather issue.
I expect that the 3LZ will do the same. The indent would seem to be a function of the foam underneath, not the covering material. I think that one guy here managed to get it replaced under warranty last year....not sure.....
Received 8,930 Likes
