Finally talked to a Mobil 1 oil engineer
#41
Another point the engineer said was about oil viscosity. 15-50 hits its high number at around 200 degrees oil temp. It doesn't get any thicker as oil temps climb. Conversely, oil temps below 200 the viscosity is proportionally less. It's a sliding scale. Oil is only as thick as it needs to be. Temp related
I too want some info around effects of these temps? Where can this be found? What are max temps recommended for track use? What temp does this oil break down and need replacing? One track session w 280-300 temps?
Would 0-40w be better for these higher track temps?
PLEASE help.
PLEASE help.
http://www.viscopedia.com/calculator...extrapolation/
I know one of the well respected Porsche race mechanics who is a part of their 24 hour endurance race programs. He said earlier on they were noticing many cars would go "almost" the distance and just before the end, blow up engines. This was obviously very frustrating for them after all the efforts. However after they increased the levels of ph/zn in the oil, engines performed a lot more reliably through the entire 24 hours.
#42
Sorry, but 0W-40 M1 is superior to 5W-30 in every way and this has been well established in other threads on other sites through oil analysis. The only thing about 0W-40 is that it starts to shear back thinner some when run for much higher mileage intervals. So long as you are changing every 6k or less no reason not to run 0W-40. For longer change intervals in warmer climates 10W-30 is just barely thicker than the 5W-30 and is also a better choice the 5W-30. GM has to allow for the customers running cars in some very cold climates when they make blanket recommendations.
I run high mileage 10W40 in my 14' CTS-V, but it has a 416 stroker fully modded at 15psi so it consumes thinner grades too fast under higher boost.
#43
Oil & Truth
#44
Options to Mobil 1 0w-40
At the Mobil 1 0w-40 price point, knock yourself out. Is available at my local Walmart for just over $5.00 a quart. I am listening!
#45
#46
OK, so I see what you've written above and please forgive me, I'm a little slow with your statement. If 0W40 is so far and away superior to 5W30 in this application (engine, C7 Z06) and with this engine oil weight it shouldn't affect any Federal emissions obligations and with the oil pricing being equal (or close enough)....why hasn't GM Engineering changed the "recommend oil fill" to 0W40? I believe we are talking about a Z06 that is used in the normal, street driving type application....occasionally wrung out on the street, rarely tracked, just normal operation of a 650 HP car (oh boy!). Is your background in automotive engineering or petroleum chemistry/engineering? I'm not setting you up here, I am serious...how can you substantiate the accuracy of your statement? If you can, I'll switch in a heartbeat. I think we should hear what your credentials are, to accept your findings. Thanks!
#47
OK, that makes complete sense if the European Corvettes don't have catalytic converters.... or do they? I live in PA, what the hell do I know about Corvettes shipped to Europe or the Middle East, etc!
#48
"As for the Mobil 1 0W40, it was not available when we validated these engines and, in its currently available formulation, it also contains more phosphorous and ash than we specify. So, even if we validated the 0W40 for track use, we would still have to recommend reverting to a DEXOS 5W30 for daily street use."
#49
Under ask Tadge section, Answered: Changing Oil for Track thread, Tadge said:
#50
Kamran, thanks very much for taking a moment and providing this information. For me at least, this really does clear up the discussion. It's been my experience over the last 35 years, if a bottom end failure occurs in an engine during the warranty period, one of the first things the manufacturer wants is to have an oil sample taken and analyzed by a certified lab for oil grade/type and viscosity. If the failure is a "lack of lub" failure (which is a "catch all" comment, whether the engine was low on oil or the oil was the wrong spec to properly lubricate the engine, both considered "lack of lub" failures), warranty will typically be denied. I'd rather stay with the manufacturer's published spec, just to be sure of warranty coverage. Thanks!
Always stay ahead of game by having your oil tested anywhere between 500-1500 miles for a base line and at next oil change. Thereafter test your oil every couple of oil change. Cost is $30 per oil test and gives you a heads up if things are going south. Also if all ok, you have proof to show GM everything was moving along just dandy!
#51
#53
Received 1,342 Likes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'22-'23
Okay, now let's discuss which windshield washer fluid we should use or which car wash soap is GM approved. Sometimes these discussions just get ridiculous.
#54
I fretted with all these same concerns at the beginning with my 2015 Z06/Z07 and finally decided on the best answer just before doing my first oil change . . . I installed 10W40 Pennzoil Ultra Platinum!!!
#55
As a side note, the dexos1 oil specification does not allow any 10W30 to be approved. This makes consideration of 10W30 a moot point as it would void your warranty.
#56
Supporting Vendor
If you don't get an oil overheating warning and power reduction you don't have to worry. GM knows where the danger point is and will make sure the engine will shut down if the oil gets too hot. They are not looking out for you they are looking out for themselves and want to minimize claims.
So far I have only seen oil temps into the mid 270s which seem to be fine to me. Far better than the 319 degrees I used to see on my C5 Z06 and low enough that the oil overheat light on my 86 wouldn't come on either, even though it ran dyno oil.
My stock C6Z would run 260 oil temp all day long at the track but I am pretty sure that 275 isn't an issue either.
Bill
Bill
To our knowledge, the oil temperature sensor for the Z06 stops reading at 311. We have never had any warnings, or shut downs due to oil temp like water temp, trans temp, or blower pump throttle shut down.
__________________
"Keeping You on Track!"
http://www.gspeed.com
877-512-5180
Instagram_Facebook_YouTube
GSpeed C7Z Cooling Development
2014 NASA Texas TT1 Champion
2015 NASA Texas ST1 Champion
2018 NASA TTU & TT3 National Champions
2019 NASA ST2 National Champion
2019 NASA Texas TT2 Champion
2020 SCCA Majors COTA GT2 pole sitter
2020 SCCA Trans Am Road Atlanta SGT Winner
2022 NASA National Champion ST2
2023 NASA National Champion ST2
2023 NASA National Champion TT2
877-512-5180
#57
Gspeed, what your thoughts on the best oil to run street verse track?
#58
Supporting Vendor
Best oil, GM warranty aside? There are several. We like motul 300V due to the base stock, and the detergents it has, keeps everything clean, yet well protected. Redline is a great oil, so is Driven/Gibbs, and Brad penn.
There are several other oils as well, but those are the 4 that come to mind.
Oil choice is just an opinion, when youre dealing with these oils. They are all good, for sure.
djnice (04-05-2017)
#59
I did. '15 Z07 7 speed, 1400 miles, stock everything, 5W-20 oil. Sold it in favor of a new ACR for track use.
#60
Probably old news, but instead of paying $9.40 per quart for 15-50 Mobile 1 I ordered on line from Walmart in 5 gal jugs. A little over $25 per jug. This will be the third year of track events on my 2015. It goes in for fluid changes, pads, and short shifter install Friday. Love these cars!
