Sponsored by: GEM Motorsports
DSC Sport Shock Controller observations
Old 01-03-2017, 07:09 PM
Poor-sha
Track Rat
Support Corvetteforum!
Poor-sha's Avatar
Received 3,400 Likes on 1,372 Posts
Originally Posted by rikhek
I've tried the OEM WEATHER mode and it does not provide anywhere near the level of comfort the DSC controller provides in PTM/WET.
I'm VERY curious about the the comfort level provided by the OEM controller in PTM/WET. I never tried the OEM controller in this setting on the highway before installing the DSC controller. As stated earlier, I just stumbled across the comfort level provided by the DSC controller as I was bored and playing with the vaious modes driving down the highway.
I'm just not sure I'm curious enough to swap out the controllers to find out...
Rick
Rick, I can't remember if your car is an FE7 or FE6 car. I will say that the OEM PTM Wet mode was softer but it was also super floaty. I'll have to try and dig up some old video but you could really see the hood lift and drop under acceleration.
The nice thing about the DSC controller though is when you put some G forces in to the car is automatically stiffens up in response. That way you're always able to respond if need to swerve to avoid an obstacle.
Mad Dog 24 (01-04-2017)
Old 01-03-2017, 07:10 PM
SBC_and_a_stick
SBC_and_a_stick's Avatar
Rick
I wouldn't be surprised if the OEM PTM/WET is considerably soft as well.
I'm also sure that GM won't soften the ride too much to prevent hitting the bump stops and destabilizing the car. Safety margins are more important for OEM systems than aftermarket.
Good find in any case. Is there also a way to have the throttle progression of Race mode with the soft suspension setting? I find this the ultimate drawback of the OEM modes. I want the Sport sound, Tour suspension, and everything else Track mode.
pdiddy972 (08-10-2017)
rikhek
rikhek's Avatar
Originally Posted by spearfish25
Rick, are you controller only or did you do the tractive shocks too?
As my C7Z is 80% street I'm on OEM shocks for now. I'm not sure that I'll upgrade to the TracTive shocks. I might but not certain.
On my 997.2 911T race car I have both the controller and the TracTive shocks. The shocks are a bargin for what they offer. Suspension **** and a no brainer for a race car.
I can say that the DSC controller alone improves the C7Z OEM shock performance significantly more than the Porsche OEM PASM shocks. Much greater opportunity for improvement on the Corvette. The DSC controller really does transform the car. You have to drive one with it to appreciate what I'm talking about. Hugh improvement.
Old 01-03-2017, 07:13 PM
Poor-sha
Track Rat
Poor-sha's Avatar
Yup. Check out the link I posted earlier. You could load the entire tour suspension setting in for track mode or just set PTM Race to take some out of the shocks all together.
Old 01-03-2017, 07:17 PM
rikhek
rikhek's Avatar
Sean,
My car is an FE6. The car was just a tad floaty in PTM/WET with the DSC controller going down the highway. However, I'm nit picking. I hate a "floaty" car and it was by no means annoying. It was damn near perfect.
It was so good I want to copy the PTM/WET calibration tables into the TOUR mode.
Rick
Old 01-03-2017, 08:00 PM
mulalleybs
mulalleybs's Avatar
If folks want to better understand how the system works here is a little tutorial on the software that I posted after I spent some time with Mike last week.
https://www.corvetteforum.com/forums...-tutorial.html
I didn't talk about the launch control in this post because I wasn't sure if Mike was ready for it to be discussed publically. However, check out the acceleration table and you can get some feel for how it helps put the power down. The new software will have a couple of additional boxes to help with the additional shock when you launch from a dead stop and are in launch control mode.
Also, you can see in the PTM table where he takes 10% out of the shock in PTM Wet which helps with the ride.
This car is really killer with this suspension.
I've saw a comment in another thread where someone stated prior to the controller they would roast the tires in second and afterwards it simply put the power down. Can you provide any insight on this?
Thanks!
Old 01-03-2017, 08:29 PM
Bob U
Bob U's Avatar
Thanks!
Improved traction (dead stop launching and 0 to 60 mph) would be a major improvement.
Old 01-03-2017, 08:53 PM
Poor-sha
Track Rat
Poor-sha's Avatar
Thanks!
I think that was Mike that made that comment. I've had the system on my car for a year now so it's hard to remember how poorly it hooked up stock but I do know that how it put down power was one of my initial impressions.
https://www.corvetteforum.com/forums...uspension.html
If you look at the accelerator table in the link I posted earlier you can also see how the car can soften the rear when you smack the gas to help soften the blow to the tires. Launch control will do an even better job of stiffening the front and softening the rear so the car just squats and goes.
Old 01-03-2017, 09:25 PM
rikhek
rikhek's Avatar
Thanks!
I started a thread about the DSC Sport controller helping put power down and Mike Levitas, owner of DSC Sport/TPC Racing commented on the subject. Mike developed the DSC Sport controller. Here's the first post from that thread followed by a link to the entire discussion. The link to the entire thread is below the alignment table:
In a different thread there's an ongoing discussion about the magnetic shock benefits realized with the DSC Sport suspension controller in road course and aggressive "twisties" driving. I have a controller on my Porsche GT1 997.2 911T race car and C7Z. I'm amazed at the improvements realized on both these cars. Others who have installed a controller express similar results.
Also discussed in the other thread is the difficulty putting power down from a standing or rolling start with the C7Z. Most don't realize the DSC Sport controller was designed to improve performance in straight line applications as well as road course and street driving applications.
Mike Levitas who owns TPC Racing is an accomplished racer and race shop owner. His credentials include winning the Daytona 24 Hours and numerous IMSA titles. He's also a long time Corvette nut and drag racing fan. The controller website is: www.dscsport.com.
Mike's a friend of mine and expressed some time back he was frustrated with difficulty putting power down with the C7Z. Additionally, he saw room for improvement from the magnetorheological shocks on road courses. Mike's chassis, suspension and setup knowledge from an engineering standpoint is world class.
I asked Mike to contribute his thoughts to the other thread. He was hesitant as he didn't want to seen as joining the discussion to promote sales of his controller. I convinced him his contribution would be welcomed.
I thought you folks would appreciate the post Mike contributed to the other thread specific to how the DSC Controller improves the ability to put power down in straight line applications:
Mike Levitas here. I thought I would chime in and try to give a few cool details about the DSC Sport controller. There are many features of the controller. One of note is the massive improvement in grip that translates in huge improvements in 60 ft times as well any speed roll-on.
My C7 Z06 M7 was so bad stock it would blow the rear tires off in 3rd gear. Now my car barely squeaks the tire.
How this is achieved is uncomplicated. The controller has an acceleration table that is used in throttle rate of change. There is a sensitivity feature so you can time the rate of change of the throttle to the compressor bypass valve in the blower.
This triggers a table that allows tuning of the magnetic dampers so you can soften low speed rear compression to soften the blow to the tire and increase low speed front rebound to slow down weight transfer so the tires are not overloaded. The result is the car flattens out with nice transfer so you don't blow off the tires.
That being said, please understand setup is critical. You must adhere to my setup on the rear uprights. Caster is king in controlling the toe curve. I'm not sure what GM was thinking with their suggested alignment setup but the car works way better with 0.75 degrees positive rear caster. Also, try to keep eccentric in the center.
I like 1.2 camber for most street cars leaving in all control arm washers. The rear toe loves to be out -0.5mm with this caster.
The secret sauce is the DSC controller so now the shocks can go way softer than stock so you don't blow off the tire. Road racing and drag racing are a lot the same in approach. I've spent time analyzing 100s of cars. Launching a good car just leaves no drama and no big weight transfer. The car just drops and leaves same as a good car off the corner and never even turns a tire.
There is so much power in the DSC controller your imagination is your only limit or lack there of. Please remember there is still the velocity tables that allow tuning of grip to the tires.
This is first digitally available aftermarket controller offered to enhance the car's capabilities.
https://www.corvetteforum.com/forums...ower-down.html
Old 01-04-2017, 08:02 AM
spearfish25
spearfish25's Avatar
Can someone explain how a driver selects the different settings with this thing? Does the controller just revamp what each mode is in the DIC? So I still select Tour, Sport, Track or any PTM mode and the changes are all behind the scenes?
Old 01-04-2017, 09:01 AM
Higgs Boson
Higgs Boson's Avatar
Received 2,379 Likes on 1,238 Posts
yes, and in the software for the DSC you can edit the suspension settings based on each Driving Mode: Touring, Sport, Track, and each of the Track PTM modes (as far as I can tell, mine is coming in today).
Old 01-04-2017, 10:02 AM
jim2092
jim2092's Avatar
St. Jude Donor '08
Will be interested in your review of this product, particularly if you should make any softening changes to the Tour mode.
Old 01-04-2017, 01:55 PM
  #33
Higgs Boson
oh intend to really mess it up.
Old 01-04-2017, 02:54 PM
  #34
rsalco
rsalco's Avatar
Will be interesting to see what difference, if any, it makes on the track. Lap time comparos. My guess is not much as I think the OEM controller is pretty well optimized for track performance. GM's testing resources for that environment are well beyond the typical after-market vendor.
Old 01-04-2017, 06:07 PM
  #35
spearfish25
Is wifi or Bluetooth built into the V2 or something coming in a later version?
Old 01-04-2017, 06:52 PM
  #36
Poor-sha
Track Rat
Poor-sha's Avatar
Yes. It might help to look at the screen shots I posted.
Old 01-04-2017, 07:20 PM
  #37
mulalleybs
mulalleybs's Avatar
seen a few people reporting around 2 seconds a lap at various tracks.
To DSC Sport Shock Controller observations
Old 01-04-2017, 07:21 PM
  #38
Mad Dog 24
Mad Dog 24's Avatar
Location: Syracuse-Central Square New York Winer of the all Corvette race WGI 8/23!
Rick, I'm interested with your opinions after a few track days as I know we are using similar track settings. My Z07 while comfortable enough to take on long trips in Tour, NY to FL.. I am getting old and notice this summer it would be nice for a bit softer ride. Interesting!
Just signed my wife up for here first track days this coming summer. Now how do I sell the need for the controller to a novice?
  #39
spearfish25
I did. It's mesmerizing, awesome, and intimidating all at once. I really don't want to get into tweaking both because I don't know what I'm doing in that department and I'm not really interested in spending any time on it. I'm more interested in plug and play improvement at the track with the potential to improve my comfort cruising ride as well.
pdiddy972 (08-11-2017)
Old 01-04-2017, 07:36 PM
  #40
phantasms
Leeds.io
phantasms's Avatar
St. Jude Donor '14-'15-'16
I'm curious. If I got this I would essentially leave it stock as I'd probably just screw it up. However for the strip is love to get the launch control settings into some other standard mode such as tour. I'd want the best for weight transfer at the track however launch control is never the best way to get a very good 60 foot. Is this doable or is the launch control settings a whole other thing? Also, would this be dangerous for any reason to roll around in this modified tour configuration with LC weight transfer ability?
Thank you!
Best,
Gene
ps. Looking forward to hearing about aggressive street performance.
Quick Reply: DSC Sport Shock Controller observations
