DSC Sport Shock Controller observations
#381
Leeds.io
St. Jude Donor '14-'15-'16
don't / won't track my C7.R either (probably - VBG) and the difference in handling can NOT really be described adequately in my feeble mind! Let's just say "seat of the pants" in taking an exit ramp that I typically took at around 40 (posted speed 25) I can NOW safely take at 60! With the controller the car just squats like it should in the turns and really NO roll, etc. that you typically get / expect. Of course this NOT a scientific response. And, yes I do drive the C7.R very aggressively when I take her out.
Soooo...wifi available yet?
#382
2020 Corvette of the Year Finalist (track prepared)
C3 of Year Winner (track prepared) 2019
Looking forward to trying out the RT shocks that arrived this morning!
Got my file updated and shocks calibrated/zeroed.
#383
#384
#385
#386
#387
Well not to control the roll and balance, but if you corner balance the car, unless you get very lucky, the sway bar will have some counter-pressure on one side or the other. The adjustable links just allow you to adjust that out of the bars so that they are perfectly neutral at rest and not pushing up on one side and down on the other.
#388
Haha
#389
Haha
As a quick note, just did 80 miles to and from the alignment shop and I swear the RT shocks feel better in my mind on the highway! Could be a placebo affect, could be brand new balanced tires, or could be the fact that I never even zeroed the controller with the OEM shocks, but I swear it rides better in my mind.
#390
Former Vendor
I can barely find someone around here to correctly align this car, let alone corner-balance it!!
If you need any help in ride Height adj let me know We have checked many of the C7 here at the race shop and they are really good out of the box. I mean really good like within 1 percent with driver and target air pressure and every car has been the same. A true testament to the chassis its super rigid and I bet every tub is exactly the same.
#391
Fantastic review and summary on the Tractive Dampers yes the ride will seem completely different and to describe the ride as nicer is due to the nature of the magnetic fluid and piston design its all 0-2"/sec range so you feel everything. This is why everyone says their car rides way better with the DSC we knock the front end of that low speed down its part of our strategy. But the Tractive is a whole nother level you get a true racing piston and shim stack with no compromise and tuning could not be any easier just down load the file off our site.
#392
Former Vendor
look to our site under technical firmware there is a wi-fi security update posting this weekend. If I get a chance Monday ill write a install guide for the update installation then you will be able to add a password and your off and running
most boxs shipped in the last 2 months have the security updates already installed I just have not had a chance to debug fully. Im afraid im a creature of habit and really use the usb for speed. the wi-fi will just add convenience when doing simple tasks swapping files zero travel and some data logging
Im supposed to be at road atlanta monday but i may delay a day so bare with me I have a tight schedule
peterjank (03-27-2017)
#396
Hi All,
After reading through this thread I was compelled to purchase a DSC Sport Shock Controller for my 3k mile 2016 Z06. Thanks, Rikhek! ;-)
I installed the unit in 30 mins on Friday afternoon and have been driving it extensively over the weekend to get a feel for the changes.
Truth be told I knew everything I needed to know in the first 20 minutes of road driving (both relaxed and moderately aggressive) but didn't want to post my thoughts immediately because they seemed like hyperbole and marketing fluff so I slept on it for a couple of days.
With that in mind, plus the fact that I'm no seasoned road racer or suspension guru I'm just going to post my stream of consciousness bullet point thoughts as I jotted them down after my first drive on Friday evening.
1. Ummmm, wow. $1290 VERY well spent. How often do I say that?
2. People aren't going to believe me.
3. Suspension in all modes is COMPLIANT! Sucks up the bumps.
4. Car just feels more planted in all situations vs. being bounced around.
5. The car now feels telepathic. It seems to know what I'm about to do as soon as I think it and prepares vs. reacting to my ham fisted inputs after the fact.
6. No tail wagging/wiggling during rapid acceleration even when I'm spinning the tires. Car just goes where I point it rather than making me worried it's going to have a mind of it's own.
7. Even Track mode is SMOOTH! I'm going to use this mode way more often on the street.
8. Amazing. Can't wait to get the alignment done.
No filter, no explanations. Just my amateur observations and opinions for what they are worth. Your mileage may of course vary.
#397
Now here's a weird thing: Since I installed the DSC on Friday the car wants to drop the passenger mirror down like I shifted it into reverse after I park and leave the car.
When I get back in and start it up the mirror adjusts back up to where it normally goes. When I get out of the car I check the mirror and it's set normally. Leave the car overnight and check in the morning and lo and behold the mirror has adjusted itself down. As soon as I start the car it adjusts up again. Coincidence? Almost certainly, but an odd one nonetheless.
I'm going to redo my memory settings to see if that exorcises the gremlin.
That is strange. You are the first to see something like this.
Did you re-do your memory seat settings?
