Rear diff low fluid
If this has already been discussed than I apologize.
Maybe the low level is because of the rear differential cooler lines after installation of rear at factory?
Received 4,553 Likes
2016 C2 of Year
2015 C3 of Year Finalist
See my post, 10, earlier in this thread. I think you are correct. The pumpkins are filled by the suppliers. Once the car is driven, the rear ends need to be topped off. Maybe BG should rotate the rear wheels, check the level and top it off.
Would there be any problem of topping off with AC Delco 10-4016? It's the same synthetic 75W-90 but without the limited slip additive so I've read. Car is jacked up ready to add but 10-4034 isn't available today.
My 2 cents, I wouldn't. I doubt anyone here has done it and ran it long enough to answer this question so why risk it, Just keep it simple and do it by the book.
you could change it all for $66 later at next oil change. Wouldn't hurt.
I replaced 3 diffs (warranty) in my CTS-V. All began to sing after 5K miles with the GM synthetic. Switched to Royal Purple 75/140 max gear oil and ran another 15K miles and 10 track weekends with no other issues. I believe the RP has a higher heat tolerance but I have nothing to back that up. Thoughts?
#33
#34
I don't think it is a mistake that the rear ends are at the lower level on fluid. Up to 1/2" below the hole is supposed to be an acceptable level, even though most people have always filled it up to the bottom of the hole. Since the rear ends are filled at the manufacturer, maybe some accountant decided they could save money by only filling to the acceptable lower level.
#35
I don't want anyone to screw up their rear diff. I used RP with friction modifier. I had a member PM and say that RP has the wrong friction modifier. While my experience was better with RP in my CTS-V, I don't want to cost someone their rear diff. Sorry for any confusion.
#36
My CTS-V ate two diffs as well. Even the third would whine but I gave up. Any time I tried a non-GM oil it would chatter despite adding the slip additive.
#39
BG cars are run on a dyno so doing a fill up afterwards should be part of the preparation before shipping. Somebody should have changed the final process by now ...
#40
Originally Posted by DAVE396LT1
Any relationship between using non-GM oil and your multiple failures do you think? I won't tell, just curious...
