Tony Mamo Ported TB installed
#101
Looking at the pics in this thread of the stock vs ported TB, the ported on looks much smoother and almost shiny. The stock one shows some fine casting or machining porosity. Most of what I have read indicates that a slight surface roughness help to break up the air/fuel molecules, improving atomization.
If you search various manifold and cylinder heads manufacturers tech and FAQs, most recommend not polishing intake paths which can reduce flow and performance. Blending port shape and improving short turn radii are beneficial, but not polishing. Any benefit from porting is likely from enlarging and blending shapes. Eliminating the smooth, polished look and bead blasting would likely improve flow additionally.
It could also be that the photos reflect light more, making the ported version appear polished.
#102
^^^ The throttle body doesn't come into contact with the air fuel mix. Fuel is injected directly into the combustion chamber.
Last edited by Steve Garrett; 03-17-2017 at 08:36 PM. Reason: No need to re-quote the previous post, especially if you're the next person posting.
#103
Said info would be correct wayyyyyy back in the days of carburetors but the DI is what it is Direct Injection into the combustion chamber and the swirled combustion chamber design will facilitate an awesome combustion event. There is a really neat article on the thousands of hours that GM spent on the combustion chamber design of the new DI engine.
RT
RT
#104
Guys,
"Polishing" a parts surface does nothing to improve flow (just adds "bling"). The whole "porting and polishing" phrase is a vestige of the 60's honestly when alot less was really known about the science of airflow.
In fact most pro's that study airflow all agree a slight texture could help as it helps create whats called a boundary layer.....that is a very slow moving layer of air close to the surface of the component air is flowing thru (intake port, TB, etc.). That provides a "cushion" (for lack of a better word) for the the much higher speed air to rush over. You can see this if you probe the port (or TB) for a velocity profile....its very slow moving as you position the probe towards the perimeter/outer edge (almost nothing right at the edge) and as you move the probe further inward (towards the center of the item your checking) the velocity increase is huge. The bulk of the air being moved is mostly utilizing 85-90% of the cross section of the part your checking.
My TB's are finished with a certain grit roll and then I have an additional step which smooths the finish to the touch dramatically.....it actually "feels" smoother than it may look in pictures or live for that matter. I have been using this same process for years now and it works extremely well.
Also more proof regarding airflow and smooth surfaces versus slightly textured.....think golf ball.....if a perfectly smooth sphere would carry greater distances, all major golf ball manufacturers would make theirs perfectly smooth yet clearly that's not the case. The ball will travel further with slight facets in the ball which helps create the boundary layer around the ball I was discussing in the paragragh above
Google "Boundary layer of air" for those of you wanting a more technical description or explanation about if any of you have an interest. There is alot to read about if you're so inclined
Cheers,
Tony
Cheers,
Tony
__________________
Please take the time to also visit my website at www.MamoMotorsports.com
The following 5 users liked this post by Tony @ Mamo Motorsports:
Bigeasyvette (03-29-2017),
george vee (03-17-2017),
Harbgrogan (11-15-2019),
Is2scooby (03-17-2017),
phantasms (03-17-2017)
#105
^^^ Well once you used the golf ball to explain it I even caught on.....HAHA
Last edited by Steve Garrett; 03-17-2017 at 08:35 PM. Reason: No need to re-quote the previous post, especially if you're the next person posting.
#106
#110
Installed mine last week and it is a keeper! Throttle response and roll-in was great, especially at the track. I believe it picked of some hp/tq but not completely sure b/c I went to a different track... prep was not great like my favorite place to race. Got the LS7 on the CTSV and this puppy on the C7Z. Great work Tony!
#112
Just another very well satisfied (thrilled!) customer who installed Tony Mamo's polished T/B. Installed last week and then had the car Ceramic pro'd. The car runs great, seems to have completely eliminated ( or very close to it!) the hesitation. Glad I purchased it, well worth the money. Thanks Tony!!!!!
#113
Order one....I will refund your money if you have any issues or port something special just a tad more conservative for you if required.
I think your going to have no issues with my standard TB but in the event you do you will have options including a full refund of the part. You have all to gain and nothing to lose
PM me if you would like to get something going
-Tony
-Tony
Previously, I have been running a Halltech CAI, tric, Torco, and Drag Wheels/Tires. My car was very strong before the last round of mods (has run a best of 10.38 in +97 DA).
While my car is torn down, i am also installing a bunch of cooling mods, Dewitts radiator, oil cooler, improved oil thermostat, LMR HX, LMR HX tank, LMR thermostat. The cooling mods will be adding 40 +/- lbs of coolant and parts to the front of the car (sadly), but i am preparing for the hot Texas summers and considering these mods a solid foundation and preparation for future possible pulley/tune mods.
After all of the talk about "going too lean" with the combination of mods including CAI, X-pipe, PTB, etc.... i decided to install the wideband for safety's sake. I will be providing feedback after i get it together and do some monitoring.
Andy
george vee (03-22-2017)
#114
Just ordered my ported TB from Tony yesterday. I don't even have the car yet, but I knew that I wanted to do his TB along with a green filter and Borla X-pipe as the first mods. I doubt I'll do much beyond that because the Z is already way more car than I need, but I figured for a few hundred bucks these mods would be worth it.
#115
#116
17 Z M7...Received my TB from Tony today. Shipped exactly when he said it would. Took maybe 10min to install. Couldn't be happier with the improvement. No more hole in the rev with a light throttle blip leaving from a stop (the main reason I ordered it). As others have said, throttle feels linear through all gears and just plain feels the way it should... Thanks Tony.... Great work Man!
#117
I received mine this past week. It was well packaged when received. I installed it this AM and started the car - no codes appeared. Unfortunately I did not have the time to take it for a drive today but hope to do that sometime during the week. So far I am very happy with the product. Tony has been great to deal with too!
#118
Leeds.io
St. Jude Donor '14-'15-'16
Ordered. Will install and review comparing it against my current Katech PTB...and will probably list KPTB for sale on the cheap if anyone's interested.
The following 2 users liked this post by phantasms:
george vee (03-28-2017),
Z0Sick6 (03-28-2017)
