Who thinks the camo front engine mule is the 2018 Z06?
Received 2,681 Likes
2018 C5 of Year Finalist
I know there is a lot of speculation due to GM's silence and delayed announcement of the camo-covered test mule, however I'm curious how many think it's a remodeled Z06 vs. a ZR1? Based on what I've read so far both on and off this Forum, below are my pros & cons that it is a Z06 vs. a ZR1.
Pros:
- Based on reports from those who have seen this car in person, the engine and exhaust note are similar to the current LT4 Z06
- Outside of the increased cooling vents (hood, front fascia, side vents) there doesn't seem to be any other major cosmetic differences to the current Z06
- Multiple different rear wing types (both coupe and convertible) meaning that the additional aero may just be a remodeled Z07 track package
- New engine type (LT5) listed on leaked 2018 GM production document, but the same document still only lists three Corvette models; Stingray, Grand Sport, and Z06
Cons:
- History of the ZR1 (C6) making it's debut near the end of the generational run
- Cosmetic hints of new wheels and blue (ZR1-only) brake calipers
- Production costs - If this is the 2018 Z06, why did GM even make subtle changes to improve the cooling in the 2017 Z06?
- LT5 listed in previously leaked 2018 GM document - Twin Turbo?
Pros:
Cons:
The Consigliere
Received 5,447 Likes
I think it's a ZR.
That's my point and the reason I started the thread.
I'm OK if it's a ZR1 as I'm targeting a $90K-ish 2017 Z06. It will be 98% street driven with a few track runs (M7).
I will be disappointed if it's a Z06 with improved aero, cooling, and HP for 2018.
The pictures of the test mules have been purposely deceiving as they have includes coupes, verts, wings, small wings, blue calipers, red calipers, etc. so that's why I'm thinking it may be the Z06.
Plus, if they release it as a ZR1, I wonder if the other aero and cooling vents will be incorporated into the 2018 Z06 or if the Z06 will remain cosmetically unchanged.
the LT5 is going in the Mid-Engine car, the Zr1 is getting another blown 6.2 with the new Eaton 2650. There is absolutely zero chance or reason that's an "updated" Z06. Vette gave up mid cycle refreshes with the C4. To spend the money on R&D it makes more sense to give it a new nameplate.
MSG C5 (01-30-2017)
Better cooling....duh;
More HP........duh.
Call it anything you want..........It is coming soon.
More HP........duh.
With the extended plant shut down previously announced, many are speculating this means the entire C7 lineup is being refreshed cosmetically however agree, after the extended C3 and C4 generations, GM has stopped mid cycle cosmetic refreshes choosing to release new models instead.
No!
Better to bring it out on a more extreme car and then let people (all those people!?) upgrade if desired.
of course but they need to differentiate the models some how to make the upcharge worthwhile.. aside from wheels/tires, do you think it costs that much more to make the stingray a "wide body" from the start. if every C7 was a wide body the reason to buy a Z/GS would be decreased and I think the cost would be almost identical with less molds and a simpler manufacturing process (all cars being the same)
The Consigliere
I thought it was cool but this one owner didn't. If they keep the Z06 the same and the camo test mule is indeed a ZR1, than there will definitely be more cosmetic differences for the C7 version than the C6.
The Consigliere
The ME will interesting as well. Some cool stuff coming.
