Maybe the best X-Pipe for a stocker, PERIOD...
this catless xpipe is a deal but no feedback on it.
http://www.ebay.com/itm/161965223594...%3AMEBIDX%3AIT
"Remember, you get what you pay for. If you buy a cheap generic brand, please do not expect the nice quality, perfect fitting item. It may require professional modifications to make it fit."
At least they're honest...
Location: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
I never installed one of these pipes or heard one that I understood had a aftermarket X pipe. Does either of the brands mentioned have that annoying drone? Is the sound just louder or deeper? I have an interest as its just another option to remove heat out of these pumpers on the road courses and I'll take an extra 10!
In NY we have a visual cat inspection requirement but if I remember these rear cats cannot be seen with the brace in place correct?
Hard to describe the sound other than its bad azz vs. stock. Look it up on youtube aor better yet find someone local to you who has this mod done but for the $ you CAN'T go wrong if your are looking for a sig. more aggressive sound over stock!
Received 4,551 Likes
2016 C2 of Year
2015 C3 of Year Finalist
My Borla, catless X-pipe is going on Monday. Can't wait to hear it. Factory, secondary cats are under the plate but can be seen when up on a lift if you peak in. Certainly could not tell they have been removed doing a visual down on the ground. I will report back on sound after I install the pipes. Ported throttle body will be soon to follow when Tony gets it to me.
Which Borla? PN?
2016 C2 of Year
Location: North/Central NJ - a.k.a. Gotti in the CFNE section
Received 1,532 Likes
St. Jude Donor '05
The Corsa X Pipe I had b/f I sold my C7 Z had ZERO drone and sounded really good as these x pipes get rid of the rear cats without throwing codes as the rear cats are behind the 02 sensors.
St. Jude Donor '06
Nothing noticeable in SOP but I bet it would have been .1 tenth slower at the drag strip b/c several have found this to be the case with the 3 inch Corsa. It makes the sound both louder and deeper and sounds great, but I like drag racing and if I did it again would probably have done the Borla b/c I can't stomach a mod that makes the car slower.
2016 C2 of Year
St. Jude Donor '05
Got my borla x-pipe installed yesterday.
All i gotta say is THIS is how the car should have came from the factory.
In track mode, the car is pretty loud. Cold startup, WOT, it's decently loud for a stock car.
After i got my x-pipe installed, since the car was fairly warm still after about 1.5 hours, and it was 83 degrees out, the car didn't seem that loud upon first start up.
But the first chance i got to hit it pretty good merging on the highway, i absolutely noticed the difference, as you should.
The car absolutely SCREAMS!
I wanna say it's close, but definitely not as loud as a long tube, catted x, NPP (in open) exhaust on an NA LS or LT1. It's damn near that loud. Talking about actual volume, not type of sound note btw.
Like my C6 when i first installed my long tubes with the catless xpipe and a borla exhaust, i would find myself revving higher in each gear now to hear the sound.
On the Z, i'm doing the same thing. It's slightly a different sound, more "raw". About 15% louder than stock when rowing the gears.
Cold start up about 40% louder.
Love this xpipe.
Love this xpipe.
I installed the Cosa Extremes and their Double Helix X-pipe specifically for sound, and I'm 100% happy w/my decision. If any ponys were lost, I certainly did not notice. Actually, to the contrary... Either way, any comparative difference on a 650hp/650tq is negligible. Those on the fence should go to a few car shows, or other gathering, and hear for yourself as sound is subjective. If you're solely looking to add HP, then I'd look beyond an X-pipe.
#33
I would rather the x-pipe set up that yields the most hp,like most others here. Modding for less power, makes less sense imho. May as well leave it stock.
#34
that's what you say,until you hear it.borla is the way to go,little money no codes,no downside.when you sell the car switch back to stock,sell xpipe.
#35
Humble or not, look at the vid in post #10. Nobody said modding for less HP. I said any comparable different is negligible.
Also, why leave it stock? That's nonsensical when I said that I added the Corsa system for "sound." Removing the rearward cats increase volume and the Extremes improved the tone without incuring drone. I also added side skirts, splash guards, floor mats, etc. I doubt that I gain any HP from those mods. You're logic is that if a mod doesn't yield HP, you should leave the car stock. I disagree.
Nonetheless, the good news is that you have options.
#36
That's why i bought my xpipe, because i wanted the car to be slightly louder. If you want real HP gains, you have to get long tubes, then a tune. Then you'll see a great HP gain.
But i didn't want long tubes, yet. We'll see how the ZR1 looks, i might even trade the Z in for that.
If not, then maybe in the future i'll install long tubes on this car.
But the xpipe for the price, 400 bucks, for the sound it gives, is worth it. And you save like 15lbs too. The stock setup is pretty heavy.
Oh and the borla does in fact add hp. It is proven to add 10rwhp IIRC.
#37
X pipe = single exhaust period. Nice 'tuned' single exhaust sound but still a single...period. I cut them out when I can or get to it because I like true dual exhaust sound especially with headers. Try it, you may never go back.
#38
I have the Borla X pipe catless since the beginning of the summer, since I have the Borla the rear end of the car is always dirty as ****... but the sound is nasty & addictive on rev match!!!
#39
With my buddy Willie. I had the Corsas on my old 2016 Z and they sound great but several folks have now confirmed that the smaller diameter 2 7/6 Borlas (same size as the stock X pipe) perform better going down the 1/4 mile than the 3 inch Corsas. Bigger is not always better.
I would just go with coated Headers. I'm partial to American Racing.
I tie mine to the rear stock cat back. I like to go quiet even with headers.
I can come and go late sometimes.
The headers really tune up the exhaust sound, less heat under hood for sure and mine were good for about 35 rwhp with a full dyno tune. Then you drop a lot of weight
My car full of gas and oil and with some weight reduction with headers and in the wheels an tires weighed a very nice 3390.
650 rwhp and tied to the Halltech tric with 3390 pound should be a rocketship and it feels like one!
#40
All the Corvette headers have a version of an x-pipe.
You get great sound. Doesn't sound like single exhaust!
