Line lock
Line lock
I need a line lock for my 2015 to do better, safer burnouts at the drags.
Have any of you drag racers tried this on a C7 Z? would appreciate any pros, cons and install info.
Also, since the 17 ZL1 come with this feature, can it be adapted to the Z06? I except it is controlled by the ECU and not compatible with the C7. May be a great feature to add by tuner that would give them an advantage over others.
Supporting Vendor
Below is a link to a "Remote Control" line lock that I engineered which was a very clean & minimal install without running any wires into the cabin of the car or really altering the OEM setup, so it could be returned to stock. You really only need to buy a line lock solenoid (Summit/Jegs) and some parts. However I did return the system to stock. Check the link out below for pics and info.
https://www.corvetteforum.com/forums...ock-today.html
Supporting Vendor
Press and hold the center button until all the nannies are shut off, one foot on the brake and the other on the gas pushing down just enough until the rear tires break free. Hold for a few seconds until you see smoke and then roll out of the box - no line lock needed.
Takes a little practice but it's pretty easy to do.
This, of course, would be the easiest solution other than the ZL-1 software version. I tried the braking idea which worked pretty well until I installed the front skinnies. With the limited surface area, the car wanted to go sideways before I did a good enough burnout. Maybe I just need to refine my technique some more due to the skinnies.
I like your setup, but in the thread link it says that you bought a kit, used a B&M part, and had a left over Grand Sport remote. If all of this is required, wouldn't is best to buy a complete after market kit? I agree that yours is very clean, but maybe that could be accomplished with the complete kits as well.
2) The two "remotes" (see pic) are from Amazon and not a left over Grand Sport remote.
I don't know what the no-name line locks from the mail order places are going for now but that along with some fittings/etc. and the Amazon remote control kit and you would have it.
This would be cheaper and I have found that the no-name line locks hold better then the B&M.
Here is a pic that should have all the info you need on the Amazon remote control kit. Photobucket has deleted all the pics in my other thread.
C7/Z06 installation.
