Spent 5 hours with dealer mechanics trying to mount front tires
Needed two new front tires....normal stock Michelin.....they let me visit the process in the shop..began at 100 pm removing front wheels..no problem....
Took 35 minutes each to remove worn tires from stock rims...then the fun began...I left at 500pm and the tires would not pop and fit the rims...they tried sitting them in the sun, a heat gun, beating on them, putting them in the tire balancing machine, wedges, prybars....5 technicians came and went and 3 men worked full time trying to get them to pop and final fit properly...lots of lubricant was used.....took videos with my cell and they worked hard and diligently...my tire front end mechanic has 38 years on alignment experience alone....even the GSM was heavily involved...no go.
They said they are all very difficult to get them to pop on Z06 Vettes, however mine was and is exceptionally difficult to get fully fitted to the stock rim.
Anyone else seen or experienced this difficulty with their Z06's?
NW
NW
Show these videos to your dealer!
I had the rear cup tires replaced under warranty and the Corvette mechanic could not get them to seal. The shop sent them down the road to a motorsports shop that sells all sorts of oversize wheels and tires for trucks. They had a machine that made short work of getting the tires sealed. With the latest and greatest machine the job is a piece of cake.
Bill
Bill
For those of you in the Charlotte, NC area, Bill is referring to CS Motorsports at 3214 S. New Hope Rd, Gastonia. They have the latest Hunter tire changer and road force balance equipment. More importantly, they know how to use the equipment for Z06 tires.
They have mounted and balanced 3 sets for me. As an example, I took them a set of newly mounted MPSS on stock wheels performed by a national chain over the course of several days. The wheels had an abnormal amount of weights. They dismounted the tires, removed 32 ounces of Murphy's wheel lubricant, cleaned up the tires and wheels, remounted and road force balanced. The finished product had one or two weights per wheel. Their prices are very reasonable. The now get all of my Z06 tire work.
Feel your pain
Been there done that, went to TWO different "Top" National Tire Centers, both called ahead of time and said No Problem mounting the tires on a 2016 Z06.......Both instances over 4+ hours with no luck.
Number one place to get done is Tire Rack in my humble opinion. In/Out just as with any other tire mount on any other car.
Mounting the tires is not the issue. They go on to the wheels just like any other tire. It has nothing to do with "Corvette". It's just a wheel and a tire. There is no reason that the wheel should ever be damaged. I have 3 different tire machines and the old school Hunter does these all day long. The challenge with the Z06 tires is getting them to seat the bead.
shakeydog (03-27-2017)
So glad you solved this problem so quickly, whereas it is still recognized by tire installers across NA as a problem.
Lol... mounting the tire is not the issue, seating the bead is. Glad we cleared that up.
Lol.... uhhhhh ya. Seating the bead is the problem and it is part of mounting the tires. It is a problem with the C7 and has been recognized as such for some time now. Plenty of rims have been damaged.
It is absolutely unacceptable for any Chevy dealer to have a problem with this.
This is where GM should make damn sure their dealerships have the proper tools to carry out repairs and provide service.
When I was a kid, I worked at the biggest tire center in L.A. for a few years.
To do the job, it required skill, experience, and having a certain touch when it comes to mating tires to wheels.
We were paid hourly, along with a percentage of sales...we were fast, REALLY fast.
You clearly have never used a tire machine and I have not solved any problem. I just do this everyday. Mounting a C7 tire onto the wheel is not an issue. That is the easy part. The tire installer in my shop weighs 105 pounds and does it all day long using the old style machine. These posts of it taking 5 guys and all this struggling is just poor training. Seating the beads requires C02. Done.
Nothing worse than people that jump into threads with nothing to contribute but to tell us how much they have done and how easy it is... when the mass majority have real world experience in trying to get the tires changed, and or repaired, first hand.
In the old days we just used a little shot of starting fluid and tossed a match at it. Scared the crap out of the newbies. Got to admit those bead blasters are a better way. Not nearly as entertaining though.
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Dealerships are for selling cars, and parts.
I already know a guy who knows how to install low profile tires. It's about the experience, malice, and tricks.
sunsalem (03-27-2017)
#33
I just went through this with a 2016 Z06 that I purchased a few weeks ago trying to get a new right front tire installed. Went to Tire Rack and had them send it to me. Took it to the installers that I have been using for over 20 years (they are Tire Rack approved) and watched 3 guys try to get the tire to set the bead for 3 hours. Finally, I had them put the old tire back on the car which surprisingly took only a couple of minutes.
I called Tire Rack and they sent me another tire and I sent back the first one. Tire rack was great about all of this! I took that tire to Pohanka Chevrolet in Chantilly, Virginia and watched them with even better equipment struggle getting the tire to mount and take the bead. They charged me $50 to mount and balance which after they got done looked like a bargain.
I have owned Corvettes since 1977, currently have 8 in my collection and run Bridgestone RF on my 2013 GS and on my 2008 Z06. I have never seen such a tire mounting issue in my life!!! I am shocked at how much effort it takes to mount the Michelin's. When my rears are gone in a few thousand miles..I will say bye bye to the Michelin RF and hopefully Bridgestone will make the tire in the size we need and I will install them or I will put on a set of Continentals....
I really would like to see how they do this at the factory. With the amount of tires they do each day I have to believe that some method exists that is better than the videos that are listed above for setting the bead!
Bobert
Bobert
#34
Maybe someone who will be going thru BG could check into it.
My guess is it is done before the wheel even gets to BG.
#36
4 days and I still haven't been able to have my Chevy dealer get my new front tires M&B for our 2017 GS Collector M&B ....................... 4 days What's up with how to get these done and hold air.
#37
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03,'04,'05,'07,08,'09,'10,’17
First, in order to avoid ridicule, I must acknowledge it’s a necro thread…..
but it must still be a relevant topic
Based on earlier reading, your best bet is to take it to tire shop that deals with cars like ours. Note the type of Hunter Tire machine referenced. Call around and ask if they have that type of machine. Good luck.
#38
CRS1962 (08-04-2023)
