Mid-Engine Corvette - Maybe Not?
#41
Difference is you pay more for options, of course your are offered more options, as you go up the line. If Caddy does get the mid-engine you will pay more, much more for the Caddy nameplate, rather than the Chevrolet nameplate. But you will get more creature comforts in the Caddy because it is a Caddy.
#42
E-Ray, 3LZ, ZER, LIFT
Received 9,606 Likes
There will probably be two models as before. The Caddy variant will have softer, wider seats, Bang & Olufsen sound system, a softer ride and only come with GM's 10 speed auto trans!
#43
The Consigliere
Received 5,432 Likes
Well, if it's going to be a Caddy, I hope they ditch that miserable, pos CUE system.
#44
#45
GM has announced the 2017 Daytona Prototype will be a Cadillac, and that the Corvette DP is no more.
How sure can we be the mid-engine new GM vehicle is a Corvette and not a Cadillac.
I thought from early on the mid-engine car would be a Cadillac for multiple reasons, and I think this further supports my theory: it will allow it to be priced much higher and sold in much lower volumes than it would as a Corvette.
http://www.foxnews.com/auto/2016/11/...s-daytona.html
I'd rather GM work on making the C7 Vette better instead of making a mid-engine one. It's already got nearly perfect 50/50 balance - what's going to be gained by going mid-engine?
marcouvo (12-03-2016)
#46
It's already got neatly perfect 50/50 balance - what's going to be gained by going mid-engine?
#47
Received 3,078 Likes
Finalist 2020 C7 of the Year -- Unmodified
C8 when?
#50
#51
The XLR failed because it looked like Ike a Corvette with all of the round edges chopped off, and had an automatic transmission.
Now all Caddies look like this.
If they make it look like a CTS, or STS, or whatever the hell they call their bricks on wheels vehicles now, it will fail again. Give it some sexy lines and a manual transmission option, in addition to great performance, and people will line up, no matter which nameplate it gets.
#52
Just posted, I think you will see future Corvettes as Hybrids or V-6 Turbos/Supercharged. I think the V-8 is on the way out, because of its weight, gas consumption, and cost.
#53
What it really needs is AWD. Jaguar has shown it can be done in a similar size car with similar HP.
#54
That is best done with a double overhead cam, 4 valve per cylinder, turbo charged V6 (uses some of the 30+% wasted energy that goes out the exhaust.). As GM said when they introduced the LT1, a low profile pushrod engine is the only way they could get it under a low Vette hood! That double overhead cam V6 would stick through the hood of a front engine Vette! With 4 per cylinder, the valves can be smaller for higher rpm capability and higher flow velocity at low rpms. A small cid engine provides lower friction, higher mpg until you put your foot to the floor. For a passenger car that is not often and it's not required for the EPA drive cycle that defines mpg values.
Also it's more than front/rear weight distribution, expect the mid engine will have ~45/55 BUT the weight will be in the center (low polar moment of inertia) for max "g" force in turns without under-oversteer.
Fun to speculate, we'll see.
#55
How do you figure better dealer experience? Every dealer I know of in our area carries Buick and or Chevy plus trucks along with Caddy.
#58
Tadge stated that they can not do AWD in the current car. Engine is mounted too low to make it work. A mid engine would solve this problem.
#59
McLaren 675LT = 42.5% front, 57.5% rear
http://automotivethinker.com/chassis...s-not-optimal/
