Street Legal Cam for Superchargers???
I own a 99 vette that'll be supercharged with a Vortech system. I want to know if one or both of these cams are capable of passing smog/emissions test? They are both listed below. I would also like some input on these cams or any other cams I haven't mentions.
Crane Cams
Part Number: CRN-1449561
Cam Style: Hydraulic roller tappet
Basic Operating RPM Range: 2,000-6,200
Intake Duration at 050 inch Lift: 216
Exhaust Duration at 050 inch Lift: 224
Duration at 050 inch Lift: 216 int./224 exh.
Advertised Intake Duration: 278
Advertised Exhaust Duration: 286
Advertised Duration: 278 int./286 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.551 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.551 in.
Valve Lift with Factory Rocker Arm Ratio: 0.551 int./0.551 exh. lift
Lobe Separation (degrees): 115
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
Comp Cams
Part Number: CCA-54-424-11
Basic Operating RPM Range: 1,500-6,800
Intake Duration at 050 inch Lift: 212
Exhaust Duration at 050 inch Lift: 218
Duration at 050 inch Lift: 212 int./218 exh.
Advertised Intake Duration: 265
Advertised Exhaust Duration: 271
Advertised Duration: 265 int./271 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.558 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.563 in.
Valve Lift with Factory Rocker Arm Ratio: 0.558 int./0.563 exh. lift
Crane Cams
Comp Cams
Both these cams are 'mild', so with a competent tune, both should be able to pass emissions, mind you, the comp cam would have an easier time.
If passing emissions is your primary concern, go with the Comp cam. If power is, then the Crane is your ticket.
02+ Z06 Cam
Part Number: NAL-12565308
Basic Operating RPM Range: 1,500-5,200
Intake Duration at 050 inch Lift: 204
Duration at 050 inch Lift: 204 int./218 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.550 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.550 in.
Valve Lift with Factory Rocker Arm Ratio: 0.550 int./0.550 exh. lift
Lobe Separation (degrees): 117
The 02+ zo6 cam is:
204/218 .551/.547 117
As you can see they are the same and make the same power. You can buy a used zo6 cam and save some dollars also.
