Active Handling wont clear?!?
We have a 2009 Z06 and we can't clear the active handling light. Checked TPMS... ok, checked YAW sensor.... ok? Stumped. Any info??
What else did you check with the TechII? You should have been able to check out all the sensors.
Does it pop-up immediately when you start it? I find it hard to believe a SWPS would look good on a TECHII yet throw a code as soon as you start the engine.
Having this same issue with my 09 z06. Start the car and service active handling comes on including little light. I can cycle through the options traction control off then traction control on and light goes away. Competitive driving mode no longer an option. What can this be? Dealer is lost says they can't figure it out. I did have the battery off for a while when doing my supercharger install. The issue started when I started the car for the first time afterwards.
Had it happen on my 2010 Grand Sport. Dealer fixed it under warranty. Steering Angle Sensor. Lots of info on the forum. Don't have that car anymore, we'll see how the C7 goes....Oh and I disconnected the battery and tried other things but it persisted and the dealer claimed it was dangerous to continue driving with the warning light on. Apparently it's not as rare as you may think.
Changed the Battery at the dealer and no fix. turns out the Tech 2 says its the Steering wheel angle sensor. they are going to order it and replace it next week.
Ill update then.
Ill update then.
