cost to relace 07 oil pan gasket
hi any one have any idea what it would cost to replace the oil pan gasket and if there is any one you guys can recommend to do the job thanks
TRUE----They at one time had casting problems with the aluminum oil pan and I had worked on that program for a while---they use evaporative foam casting and had several porosity issues in the corners of the pan. There where a ton of field failures!!
went for oil change the tech told me it is sweating no dripping on the ground yet the car is an 07 with 13k dealer says out of warrenty though luck you have to pay told them to talk to the gm rep which they refuse
haven't spoken to gm yet but dealer refuses to speak to district rep on my behalf want me to pay for repair
