ontario e test......pass or fail......
I have a 1998 c5 corvette with aftermarket exhaust no cats and xpipe.
I had a tune done.......i think i should pass my etest....
But i am concerned....has anyone here passed without cats on there car? Any tips or recommend a shop in gta, thank you.
I'm going this week, '08 Z06 with heads/cam but full stock exhaust. Wish me luck
If you don't have a check engine light then it should pass. Adjusting the tune to still pass an Ontario E-test is pretty simple even with the cats removed. Anyone charging for a tune better know enough to set the rear O2 sensor DTC's to no error reported when tuning after the cats are removed. Same applies to the AIR system, the AIR DTC's get turned-off when you tune after removing the AIR system. Once the DTC's are turned-off the car will pass an e-test no problem even with the systems removed.
Well, I PASSED ! Heads, cam, intake and Arun/DaSilva tune........no issues and zero 'not ready's" on the report
I was worried as my 'now in the garbage' Ctek 7000 battery tender let me down this winter, allowing the battery to go so low my radio presets were gone.......and my buddy who did the etest told me weeks ago to not disconnect the battery.......
Purchased the Noco Genius 7200 tender, brought the battery back to full charge.....
So out of storage today, drove around for a bit and off to the test - done and passed !
Went to get my sticker for 2 years and good to go
*** Still a fricken cash grab - let's hope they dump this system like BC (I think it's BC) did.
Great to hear ! I just learned all this the last few weeks. I picked up a ctsv with longtubes and exhaust but no cats. I'm weighing the tune vs just adding cats.. Imo the sound is a little much for a family car
Mine passed in March with Arun's tune, headers and only 2 O2 sensors.
Had one code stick on I think because of a broken temp sensor that I replaced and a dead battery. Could not drive it enough in march to clear codes.
That cats are gone and the exhaust stinks but it does not matter as no sniffers now. Its louder now too!
