Magnuson Heartbeat Supercharger Sneak Peak
Just came in a day or so ago.
Installation in the next week.
Champion Motors bolting on a built 402ci motor at 10.5:1 compression motor.
Also ordered Magnuson's smallest pulley, a 3.2 so we can make some decent boost, at least till we turn it up further.
Top part of the Hearbeat, dual intercoolers
Bottom or business end of the S/C
Installed a 8-rib OD crank pulley
Fast intake removed. We changed the water pump with the inlet on the drivers side. Necessity so it clears the snout of the SC
Why I went with a roots blower this time round. Went with a 3.2" pulley with OD crank so hoping for 8-10lbs of boost on a built 402ci. Motor made just under 500rwhp itself, so hoping for high 600's rwhp with the blower.
Blowers coming along. This was a LS3 C6 blower, so there was some custom routing and bracktry and ingenuity that had to be applied to install. Not a big fan of the supplied intake, so Chris is going to custom fab up the Vararam up to the blower!
Preliminary runs, with safe AF's, especially in this hot humid weather.
Tuner rolled on the throttle, until we get the built 4L60 installed next week. Figured at these torque levels, flat stabbing with stock tranny and torque converter wouldn't be wise.
