Looking for one brake caliper seal
By accident I ripped one of the brake caliper piston seals on the drivers rear when I was installing the pads and have to replace it. I've called around and it seems the soonest I can get a replacement set is from Napa and it would be mid next week.
Does anyone have a spare new one that I can buy, or borrow and replace when I get the order in from Napa. It's not the one that the two halves go together, it's the one that seals around one of the 4 pistons. The other three are good so I only need one.
It's for a '75 Coupe.
I believe you probably tore the dust boot - you can probably get by without it or with a damaged one for a short while.
I find it very hard to believe that no one (in the GTA area) has a caliper kit in stock.
My local parts store probably would have been able to get one for tomorrow (if I had ordered today)
The caliper seal kits are the same for rear (or front) from '65 to '82.
I looked to see if per chance I might have had a loose seal ; unfortunately all I have are complete NOS AC Delco GM kits which I will not lend or part out - sorry.
Be forewarned you are probably going to have leaky "calipers" and will have to redo them anyway not just the one piston boot you damaged.
Thought I'd really show you how "good" I am and get you a kit today, but unfortunately I can't as the closest warehouse with stock is Boucherville, QC and it would be Tuesday
They're in stock across Canada all except Toronto
Thanks for the reply QIK59;
Before the car was parked I installed rebuilt stainless sleeved calipers. When I went to bleed the brakes I noticed a leak in one of the rear seals and figured I must have ripped it when installing the pads with the aid of a slotted screwdriver which I know is not the correct way to do it. When you're in a hurry you don't always take the necessary precautions.
I made sure to inspect each piston as well as seals before installing the pads and all were still in great shape so I only wanted one seal to replace the ripped one to get the car road worthy for next weekend. Afterwards my intentions were to replace all 4 in the one caliper, (while I'm at it).
Napa stated they maybe able to get it sooner but I need to move the car into the center of the driveway today and wanted to drive it over rather then manually move it. Brakes are helpful when driving a car for what ever reason.
The people that have stuff like that kicking around usually aren't into forums (like me ).
As I told you I could have got you a kit for today (noon).
It's not a big deal to move a car around with a leaky caliper - it's not like you don't have any brakes plus the parking brake ?
Hi Frank.
I came across this ad on Kijiji today. Maybe he has the brake seal you're looking for. Cars a 78 but he's parting it out. He's located in Caledon so not too far away. Might be worth a call and/or drive for a look see.
http://www.kijiji.ca/v-classic-cars/...ationFlag=true
Former Vendor
I have all this sort of stuff in stock at the shop. Brakes, suspension, weatherstrip, etc, all years C1-C6. If you still need it let me know, i can overnight it if you want, or not too far if you want to pick up in niagara. I'll also be in Milton tomorrow afternoon if you want to meet there. Thanks
