Canadian Events Canada, eh?
OBD scanner
Old 09-22-2015, 02:57 PM
infernobuster
infernobuster's Avatar
Default OBD scanner
Anyone in Durham region have an OBD scanner, that can quickly scan my car for whats causing my check engine light to come on ..
Old 09-22-2015, 06:11 PM
formula1nut
formula1nut's Avatar
Default Maybe another way
Not sure what car you have. If it is a C5 try this:
http://www.stengel.net/diccodes.htm
Generally with a C5 you don't need a scanner. Car has it built in!
Hope this helps.
Old 09-22-2015, 07:53 PM
RDBVETTE
RDBVETTE's Avatar
I can help. send a pm
Old 09-23-2015, 08:32 AM
74Ken
74Ken's Avatar
i have a cheap one, North Oshawa
Old 09-24-2015, 09:38 PM
infernobuster
Many thanks go out to RDBVette for hooking up his scanner and pulling the code.
Now its time to research and find out what the issue is from here.
Old 09-25-2015, 06:53 PM
RDBVETTE
RDBVETTE's Avatar
I was happy to help. Any success with parts?
Old 09-26-2015, 09:19 PM
infernobuster
Its a pretty easy fix. Havent sourced out the parts, and really cant find the time to fix it right now.
Saw you got the car back, as i passed you guys headed over the new 407 extension bridge.
To OBD scanner
Quick Reply: OBD scanner
