C7 headlights for Europe
Does anyone know if a C7 Vette manufactured for the Canadian market would have European standard headlights, or the US ones?
If there is a Canadian reader here, could probably check on the headlight plastic itself for the E or e marking.
Thanks.
Thanks.
Highly unlikely (99% sure) that Canadian spec cars are not the same as Europe. Many of us have imported Corvettes into Canada from the US and we don't have to modify our cars which would indicate Canadian and US cars use the same lighting.
The thing is that Canada will accept either US or European standard headlights.
The question is, for a C7 manufactured for the Canadian market, does it have a US or a European headlight?
Some one will likely chime in on the thread soon...
If you can't get an answer perhaps call a Canadian dealer and ask them for the part number of C7 headlights. Do the same for US and Europe and see if the part numbers are the same or not. Not sure if it will give you a definitive answer but worth a shot if all else fails.
I would suspect also that the Canada headlights are the same as the US as my C5 came with all red tails and reverse lights the same as the US and not the amber signals and different reverse set up for Europe.
Will be on the lookout for a C7 for you either way and if I find anything will post up here.
Thanks.
