Canadian Events Canada, eh?
Hazardous Material - Border Crossing
Old 02-20-2017, 08:14 PM
NoOne
NoOne's Avatar
Default Hazardous Material - Border Crossing
We want to go to St. Thomas this spring to the drag strip. I didn't think too much about it but I run methanol with the super charger and would like to bring about a gallon with me.
We'll probably do the track and then head to Toronto for the rest of the weekend before heading home.
Anyone know the rules for transporting small amounts of what I assume the Canadian government would call a hazardous material? There is the BIS hotline but its automated.
Old 02-20-2017, 08:34 PM
Zeeman28a
Zeeman28a's Avatar
Here is the Canada Border Services website for Dangerous Good and Materials.
To avoid the hassle, it might be better to source locally.
http://www.cbsa-asfc.gc.ca/publicati...-13-5-eng.html
Methanol probably falls under the Dangerous Good Section.
Will U.S Customs even let you export to Canada?
Old 02-20-2017, 08:47 PM
79 Bullet
79 Bullet's Avatar
i would not sweat it. If anything I would put it in a red gas can and keep it in your trunk. No different than carrying some gas. You have it in your car tank anyway, so if you don't make a big deal it won't be. The worst thing that can happen is they will take it. As a back up maybe someone from South Western Ontario can chime in and let OP know where to get some locally
Old 02-20-2017, 08:52 PM
NoOne
NoOne's Avatar
I did email them along with the hazardous material rating.
US customs does not check when you leave, it is all up to the agents on the other side, same is true re-entering the US.
The only issue with sourcing it locally is if I leave the house full I figure 6 runs will drain it. I only need 1.5 gallons to refill and its sold in 5 gallon containers. I use a 5 gallon container over 15 tanks of gas on average so will have lots of extra meth.
We are going to Montreal for F1 and I want to take the C7 to that too so I need to bring more.
I put it in MSR fuel bottles when we travel, same you'd use on a bike.
Old 02-20-2017, 08:55 PM
NoOne
NoOne's Avatar
Before 9/11 I would have. Hell I used to bring all kinds of stuff back and forth as far as car parts and such.
Today I would not. Because the second question after what's in the gas can if they are smart is do you have it in the car which I do.
It's in the windshield washer reservoir.
Old 02-20-2017, 11:15 PM
Black 03 Z06
Black 03 Z06's Avatar
Why don't you contact St. Thomas Dragway directly and ask your question. Fuel cars have been coming from the US since the early sixties so I am pretty sure they will know.
Other option is contacting the East London Timing Association in London, Ontario and ask the question. Lots of knowledge there.
Good luck. St. Thomas is a great facility that I have enjoyed for years.
Old 02-21-2017, 02:20 PM
walleyejack
walleyejack's Avatar
Murray always the answers, problem solved.
Old 02-21-2017, 03:35 PM
dankhts
dankhts's Avatar
the SC guys I know tell me it's just the same methyl hydrate you can buy at any Crappy Tire or similar type place by the liter... I've watched a buddy add some to his snow meth tank before as well.... shouldn't be an issue, nor a mystery?
Old 02-21-2017, 06:31 PM
7t2vette
The ORIGINAL and bestest
Support Corvetteforum!
7t2vette's Avatar
Toronto Events Coordinator
Methanol, methyl hydrate, methyl alcohol, wood naphtha, wood alcohol and carbinol are all names for the same chemical compound.
If you are worried about bringing your own, methyl hydrate is readily available at most Canadian hardware and building stores:
https://www.homedepot.ca/en/home/p.m...000130947.html
https://www.lowes.ca/paint-thinners-..._g1441530.html
http://www.canadiantire.ca/en/pdp/me...-0497127p.html
https://www.homehardware.ca/en/rec/i...mg0/R-I1620044
http://www.rona.ca/en/hydrate---meth...ate-2000208--1
Old 02-22-2017, 01:11 PM
Dodosmike
Dodosmike's Avatar
Would Isopropyl (sp?) alcohol work?
Iso is rubbing alcohol.
I run Iso in my snowmachine fuel as an anti-freeze additive, have for decades, never an issue.
Old 02-22-2017, 05:22 PM
dankhts
dankhts's Avatar
I used to alcohol and or methyl hydrate to the gas on my flat track bike when I ice raced - did it for years as well, no issues....
labels on gas line anti freeze all say "contains methyl hydrate"
Old 02-22-2017, 06:34 PM
Dodosmike
Dodosmike's Avatar
I was told that mythel would keep the water from freezing and Iso would mix with water and burn it (slight backfire from water hitting the cylinder), but no scientific facts to back it up
were off topic. Sorry
OP buy your methyl here.
Old 02-22-2017, 08:31 PM
dankhts
dankhts's Avatar
So for even more unless info, when I couldn't get race gas that I would add methyl hydrate to in the winter for an event in Quebec to prevent freezing up we'd use 110 octane aviation fuel which contains antifreeze .... Apparently 105 doesn't as the planes that use 105 don't go high enough to need 110 with anti freeze ...
Now we're really off topic!
To Hazardous Material - Border Crossing
Quick Reply: Hazardous Material - Border Crossing
