Best tire dressing for natural black look?
I wanted to add, and someone mentioned it on the first page. IMO the key to making any tire product look it's best is using an applicator (sponge etc). Sold at any auto parts store.
I try all kinds of tire products and regardless of it's intended application instructions, I use an applicator. Whether it's a gel, spray or whatever.
It also keeps the tires from slinging any product onto the car.
Former Vendor
This original post started in 2005 ... and many water-based products are now available in a matte or natural look. Poorboys immediately comes to mind ....
It should also be noted that Pledge has absolutely no real UV protection designed or added in it. While this may not be as needed inside due to the coating and tint on glass, materials on the outside of a car (trim, tires, paint) can all benefit from additional protection from the sun. 303 has it
I have used Adam's VRT for a few years. Over the last year I tried a few different products. I am at the end of a few different bottles and will be back to VRT.
Another vote for Aerospace 303.
Former Vendor
Shine Supply 'Decked Out'
http://shinesupply.com/collections/w...ts/hyper-shine
Water based dressing that you dilute to suit your needs. At the shop I like a glossy tire so I use it 1:1 (one part water to one part product). However, it can be diluted down as much as you see fit to achieve the desired finish
Dilution ratios:
1:1 = High gloss
2:1 = Satin Finish
3:1 = Low gloss
Water based dressing means NO SLING and no greasy feel
Recommend that you apply with a foam applicator
Dilution ratios:
1:1 = High gloss
2:1 = Satin Finish
3:1 = Low gloss
#34
Griots creates a satin /matte black with one pass of their rubber dressing & blue sponge
You have to use the Rubber Prep to strip all the crud off first; 1/3 of bottle goes to get it off...
#36
#37
In the past I have used Aerospace 303,not enough of the look I wanted. Zaino Z16,really liked this one but durability seemed to lack IMHO. And have been using Chadwick's No Sling Tire Dressing for 18 months,deep black with matte to low sheen. Lasts a long time. Very Good Stuff.
#40
Received 1,295 Likes
2022 C1 of the Year Finalist - Unmodified
2021 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
To me, a good scrub with soap, followed by coat of 303 makes them look "like new", as opposed to shined up.
