overspray mist on windshield -- how to remove?
11-01-2006, 09:11 AM
i've some very faint paint overspray mist on part of my windshield.
whats the best way to remove it without using the obvious such as paint thinner or the like?
11-01-2006, 09:29 AM
Uber Waxer
Cruise-In 8-9-10-11 Veteran
CI 9, 10 & 11 Car Show Winner
St. Jude Donor '08-'10
clay bar should take care of it.
11-01-2006, 10:00 AM
Quote:
I have done it on a windshield before and you can use your fingernail a little too with the clay since it's the windshield you can't rub marks into it with your finger.
11-01-2006, 12:24 PM
ok got it, thanks guys. i've got a claybar and will do it
11-01-2006, 09:06 PM
0000 steel wool and your favorite glass cleaner would take care of it also.
11-01-2006, 11:39 PM
If the area is not too large, try a new single-edge razor blade with some QD on the glass.
11-02-2006, 07:01 PM
St. Jude Donor '10
Quote:
This is what I would do on glass.
11-03-2006, 04:08 PM
Location: E.C.S 402 Stroker, Who wants To Taste It! 3:73'S 520 RWH 496 TQ in Los pantolones
Clay bar
11-06-2006, 03:17 PM
I had the exact same thing, clay bar will do the trick.
11-06-2006, 06:14 PM
Thats what I've always done for overspray, bugs, etc.
11-06-2006, 10:47 PM
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
Another vote for the 0000 steel wool here. Learned that trick from a very good body man, works great.
11-11-2006, 10:12 AM
some great ideas for the mental tool box, thanks guys.
i used a clay bar, right after i made my last post. it was a fairly small area.
i worked perfectly
to all
04-07-2015, 07:04 PM
Red Tornado
i worked perfectly
to all
Took my CB 12 to the dealer to re- paint the hubs. They got the hub gray spray paint all over the windows. Favorite Glass Cleaner, Clay Bar or blade did not work. All help welcome. Won't go back to them - even for routine services.
1of 109Made
04-08-2015, 08:38 PM
Former Vendor
1of 109made
1of 109Made
http://www.autogeek.net/diamondite-glasswork-kit.html
or
http://www.autogeek.net/dp515.html
04-13-2015, 01:31 PM
J Z06
FOAMING glass cleaner would take care of it also.
