Best way to clean a white vinyl top?
whats the best way to keep that white vinyl top looking clean and bright?,, conditioners too,,, thanks rj
I would try one of the good ragtop cleaners like 303. I think they have a vinyl version also. If desperate I would try Wesleys but I really do not think that that would be too good for it. You may also want to try Spray Nine.
I really like raggtopp for my cloth top. Haven't tried the vinyl top products but that's what I'd suggest.
In the old days, I did a lot of cleaning of cloth tops with IVORY soap - the bar of soap right from the bath. Very effective if you have some stubborn greaying or stains. But I do NOT suggest using this on any regular basis - neither in your shower nor on the car -- VERY alkaline - so it'll dry up skin as well as leather, vinyl, and paint surfaces. Probably not much different than using Wesley's Bleach-white.
Comet
You guys will probably crap when I tell you this but I have had verts since my first '47 Ford. My first whie top was my '67 Vette and one day I got mad about dark spots and tried a little Comet cleanser. I made up a little paste with water and rubbed it on the spots and they came out. Some people think it will weaken the threads but I've never experienced that and my top stays super white! Make sure you rinse it good and watch for run downs on the paint.
I have two Corvettes with white vinyl tops, and they are always bright and immaculate. I use the common household cleaner, Soft Scrub with Bleach, on the top once or twice a season if the top looks little "off", and it works great. I've heard that this shouldn't be used every time because the bleach content will weaken the threads of the top, but I haven't experienced that at all. I only do this once or twice a year as the tops never get "grungy" at all...it does make a difference.
Elaine
Elaine
Location: Ponte Vedra Beach / London State: Dazed and confused
Typical Vinyl Top Composition:
Double texture vinyl by Haartz, a four-ply composite comprising;
1.A PVC outer layer
2.An un-dyed 100% cotton sheeting backing material
3.A butyl-rubber inner layer
4.A 100% cotton drill lining fabric
Cleaning Methodology:
•Use a quality wash concentrate (P21S® Total Auto Wash) to remove most of dirt and oils from the surface
•Shake product for 30-60 seconds to ensure even mixing
•Treat spots with a Vinyl cleaner (303TM Fabric & Vinyl Convertible Top Cleaner) and a soft horsehair brush to agitate and then remove with damp 100% Alpine DFTM Microfiber towel
•Apply a vinyl dressing (Zymol® Vinyl Conditioner) with clean, damp applicator. This will re moisturize and condition the vinyl surface let dry and then buff it dry with a clean towel.
•Apply a UV protection (303TM Aerospace Protectant) keep about 6-8 inches above surface and using a back and forth movement spray lightly but do not soak, let set-up for 30-60 minutes, buff with a clean 100% cotton cloth to set the resins - 303™ products retailer search
Common Stains:
Bird excrement, tree sap, road tar, grease and oil, to remove these stains, 303r'M Fabric and Vinyl Convertible Top Cleaner will lift and suspend the soil, let it soak-in (but do not let it dry) Then rinse with clean water and wash / rinse as normal and re-apply a UVR (303 Space Pprotectant)
Alternative product- if a bird or sea gull has used your car's cabriolet top for target practice, this product will remove it without damage to both vinyl and cloth. It will not harm the tops water repellence. Poop-Off Bird Poop Remover is a non-toxic, biodegradable, active enzyme formula that removes droppings and residues composed of all types of avian diets including, seeds, fruit, nuts, meat, vegetables, nectar, bugs and grains. Originally a marine product, it will not harm the tops water repellence http://www.properautocare.com/
Do not use household cleaners, powered abrasives, steel wool or industrial cleaning products, dry-cleaning fluids, silicones (petroleum distillates) bleach, harsh detergents, or products with a high solvent or alcohol content as they will compromise the water resistant finish, the special adhesive used for the seams and cause the stitching to fail.
Knowledge; [and the proper methodologies are the key to correct automotive detailing]
1.A PVC outer layer
Common Stains:
