Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Help for streak free glass
Old 02-26-2007, 12:59 PM
dbriana
dbriana's Avatar
Default Help for streak free glass
My back hatch glass seems to streak no matter what, when I first got it there was wax on there, I used blue dawn to take off. Then I used Invisiglass, still streaks in the right light. What can I do to have it perfect? Should it be waxed, I didn't want to do that since I used the Invisiglass for last minute at shows and then it streaked, should it either way?
Old 02-26-2007, 01:11 PM
mrosa65
Support Corvetteforum!
mrosa65's Avatar
Just a few quick questions.
Is it streaking on the inside, outside or both ?
Do you have factory tint or aftermarket ?
If you don't have aftermarket tint/film, I would try spraying it down with some isopropyl alcohol and distilled water. A 50/50 mix should do the trick. After that I would use Stoners invisible glass with a microfiber towel. This of course applies to the interior glass, for the exterior I would use the 50/50 mix and stoners as well.
Old 02-26-2007, 01:56 PM
dbriana
dbriana's Avatar
no tint, outside only, but will do both with what you suggested, thanks.
Old 02-26-2007, 02:36 PM
Bandit 00C5
Bandit 00C5's Avatar
2023 Corvette of the Year Finalist - Modified
2022 C5 of the Year Winner - Modified
Not sure if anyone has had the opportunity to use the Adams glass cleaner yet, but I went to their detailing day last Sunday. The glass stuff they have is simply amazing. Comes off very easily with zero streaks. On the way home on our cruise I forgot that I had a windshield it was so clear. If you get the chance to pick it up I highly recommend it.
Old 02-26-2007, 08:58 PM
AbsolutHank
AbsolutHank's Avatar
Hell, I don't even use window cleaner. I just use Adam's quick detailer..it always leaves a streak-free shine. I use it on the glass in the house too!
Old 02-26-2007, 09:50 PM
gmblack3
gmblack3's Avatar
Do not use 50/50 on your tint.
Old 02-26-2007, 10:36 PM
rodfl99
rodfl99's Avatar
Default Adams
Where do you order the Adams glass cleaner from?
Old 02-26-2007, 11:22 PM
Bandit 00C5
http://www.adamspolishes.com/site/pr...4477842A53713D
Old 02-27-2007, 08:25 AM
KarlK
KarlK's Avatar
Location: Beats UD regularly playing 3D chess, and at life
Stoners Invisible Glass
Old 02-27-2007, 06:20 PM
owebo
owebo's Avatar
St. Jude Donor '11, '16
Try newspaper, you may be pleasantly surprised....
Old 02-28-2007, 07:39 PM
JVM225
JVM225's Avatar
St. Jude Donor '06
Stoners and Newspaper work for me.
Do the inside in a horizontal motion and the outside in a vertical motion. If you still see streaks when your done you will be able to easily see what side they're on.
Old 03-04-2007, 07:43 AM
Phanni
Phanni's Avatar
Received 1,731 Likes on 847 Posts
Use a mico tech rag for the final finish.
Old 03-04-2007, 08:54 AM
TOGWT
TOGWT's Avatar
Location: Ponte Vedra Beach / London State: Dazed and confused
Glass Cleaning Cloth:
This Microfiber 18” x 18” (Norwex) glass cleaning cloth has a super tight knit, lint free, cross-weave construction traps and collects water and is so effective (use damp) at cleaning glass that often a glass cleaner chemical (Stoner’s Invisible Glass) isn't even necessary. It features a very low-pile cut in a zigzag pattern, which literally attracts and removes off gassing, residue, smudges and oily fingerprints. Its efficient cleaning action is truly a time saver Norwex Glass Cleaning Towel - http//:www.detailersparadise.com
Alternative Product: Cobra Waffle Weave Glass Towel - http://www.autogeek.net/ww1627.html
Lint-Free Surgical Towels http://towelsbydoctorjoe.com/5.htm:
To Help for streak free glass
Quick Reply: Help for streak free glass
