Claybar question
Claybar question
I did the Zaino thing for the first time the other morning with the same results everyone talks about. The Monterey Red in the sunlight is gorgeous. Is this a great country or what. Anyway, I am curious about how I could claybar the entire car, and not see ANY dirt whatsoever on the claybar. I did the dawn wash, then did the claybar with the Zaino wash as a lubricant. No dirt. I received the car in March, use it as a daily driver. I did wash it all the time and always was waxing it with Meguiars NTX. So, either I did the claybar incorrectly or the car was extremely clean. Suggestions? Yea, Zaino rocks.
Your car was probably clean. I usually do not see much buildup on a claybar since I wash the car thoroughly before I use one. If I did see a lot of dirt on it I would stop claying and wash it again.
I find that a clay bar doesn't do much for a well maintained and regularly cleaned car. It's good for paint over spray and for a car that sits in very polluted and dirty conditions for a long time with little or no maintenance to the appearance. Save you time and money as on most cared for Corvettes it's a waste of effort.
The only time my claybar was dirty was when I was using it on my 10 year old truck. I learned about the bar and used it for the first time. A lot of work, but worth it. On a new car you should not see very much, if anything at all.
CF Senior Member
I used a clay bar a while back and didn't notice much, if any, contaminants on the clay. I have also been using Meguiars NTX but recently bought the Zaino 'kit' which I hope to get-to soon. Looks like I'll be clay-barring the car once again.
YOU FOLKS DO KNOW A CLAY BAR IS ACTUALLY AN ABRASIVE AND WILL CUT THROUGH THE PAINT IF USED TO MUCH. IF YOU CAR IS REALLY BAD THE TRASH HELD IN THE BAR MAKES SCRATCHES IN THE PAINT THEN YOU MUST USE FINISHES FINISHING COMPOUND BY 3 M TO REMOVE SCRATCHES.
z51vett
z51vett
Your car is reletively new and you've maintained it well...no mystery here.
Zaino's recommendation to clay bar is de rigour because they don't know how degraded and abused the vehicle. Clay bar gives them the best starting place they can have without specifying a lot of work that will depend on the condition of the finish. Actually, you have to be careful with claybar...you can end up in worse shape than when you started if you're careless.
I just Zaino'ed the family hooptie...it's more than ten years old with little or no wax, and a history of automatic washes. The clear coat was showing signs of beginning distress on the top surfaces. I did the Dawn wash and clay bay...pulled a moderate amount of yellowish brownish material off the top surfaces, but not an excessive amount. Since it had a lot of micro-scratches in the clear, I then decided to buff it gently. I managed the buffing without catastrophe, and got it to a point where I said "Zaino is going to have to take it the rest of the way".
It turned out very nice; not new car paint, but I can have a little more confidence the clear will hold out now until we make the trade.
