Waterless Car wash
I tried ONE from Chemical Guys, actually I only tried it once or twice and that was to remove some light dust. If the car is really filthy it gets washed with soap and water.
However, I have used Optimum No Rinse (ONR) which I've found to be very effective and if used as directed it does not scratch. You simply mix two capfuls into a bucket of water and use a microfiber cloth to wash the car. It's not waterless per say but doesn't require a hose.
Autogeek sells ONR, check it out. http://www.autogeek.net/optimum-no-rinse.html
Former Vendor
might have to look into that ONR. Unfortunately, here in Atlanta, we don't have the option of soap and water, unless you go to the coin wash, and that isn't optimal either. I hand wash, but the soap starts to dry before I can wash the whole car and put more quarters in to rinse.
I just picked up another gallon of ONR (my car is black) but in reality since it's concentrated even the 32oz bottle will go a long way.
Dri-Wash
I have been using Dri-Wash on all my cars for years with fantastic results. Goes on and off very easy and leaves a high-gloss shine. I feel its best to wash the car first but there are times when I'm on the road at a hotel where there is no water available and the car is dusty and I have used Dri-Wash on a dry car with no issue.
http://www.driwashsolutions.com/
ONR is fine once diluted in water but as a QD it is somewhat intoxicating.
Former Vendor
http://www.autogeek.net/dp-rinseless-four-in-one.html
Former Vendor
The Optimum No Rinse and the Chemical Guys Hose Free Eco Wash are the two products of choice for this task in my experience. They help you wash without having to hose the vehicle after.
Greg @ Detailed Image
