How to clean Dash?
How to clean Dash?
What's the best way to clean my black dash? I've just used water so far, but now it needs something more. Is armour-all ok? Your suggestions please ...
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
there are two trains of thought: some kind of chemical protectant, and none.
generally, a nice clean rag, wetted with water is a good first step. and for some, it's the last step.
others will use something, be it Lexol's vinyl protector, 303 Aerospace, Meguiar's vinyl protector, something from Zaino, etc.
most of these are very low luster, meaning they don't shine back at you, nor do they collect more dust/dirt since they're not sticky/tacky. they also protect against UV rays which can deteriorate plastic (and leather and carpet, etc.) quicker than normal.
armorall generally falls into the sticky tacky and shiny category.
I've done both, even on this car. just using a very clean rag and water. and even using a little 303 Aerospace (available over the internet or at some hardware stores like McGuckin)
but the one poster is correct: if you have HUD, you don't want to get anywhere close to it with vinyl/dashboard chemicals.
I use Aerospace 303 it does a great job.
Come on......its the Corvette Forum, use the most expensive product you can find! Standard answer...."You're going to use that cheap XXXXX stuff on your $65,000 Vette?"
Lifetime NCM Member #2497
But the OP said "clean", not "protect". Armor-All makes cleaners too, so perhaps that's what he's referring to.
I'd try a Mr. Clean sponge first. Cleans well and leaves a very matte finish. As an alternative I'd go with the Meguiar's interior detailer, but of course there are a number of similar products on the market.
For protecting (which it probably doesn't need), the 303 is Good Stuff. Almost no shine or stickiness.
St. Jude Donor '15
"In honor of jpee"
So I stick to warm water on a rag, done once every couple weeks.
I use an interior duster, then finish with Meguiar's interior wipes. We have a vert with ebony interior, and have found the wipes remove any suncreen residue from the center console with ease. With the wipes you don't have to worry about overspray or getting the liquid in that really steep angle between the dash and windshield. Leaves a matt finish and doesn't tend to attract dust.
