Ask the Autogeek! Question & Answer Thread
#841
Former Vendor
#842
Former Vendor
I just bought the Porter Cable Blackfire package. The videos I’ve watched about polishing with a DA always shows the person working on the center of a flat hood. What about the places where you can’t have the entire pad on the surface? Does the DA still make it safe if I’m working where I can only use a couple inches of the 5” pad? I guess I’m asking if the technique has to change when you get to the smaller places and the edges.
http://www.autogeek.net/dual-action-polishers.html
#843
C6 - Headlights - Film inside.
My C6 headlights are getting a film or haze similar to the common build-up that accumulates on the inside of the windshield. The lights look great, no visible cracks, chips or imperfections... just a noticeable haze accumulating.
How do I clean this?
#844
Received 4,504 Likes
U.S. Air Force
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Former Vendor
#846
Thanks for the response. I was afraid of that answer....
Unfortunately there is no easy way to repair this film. There are often small rubber breathers on HID lighting to allow the heat to be removed. These tubes can also allow air, dirt in. I have heard of some blowing into these carefully with mixed results. Most the time the lenses needs to be removed and then sealed back together afterwards.
#847
I parked next to automatic landscaping watering. It went off and then car sat in full sun. I've got waterspots. First I tried crystal mist,then souvergn paste wax. Didn't work. Then I tried paintwork cleansing lotion. I've still got waterspots. What should I do now? Thx
#848
Former Vendor
http://www.autogeek.net/best-water-spot-remover.html
#849
There are waterspot removing products available. I might suggest soaking a rag in white vinegar, wipe area, and then wash as normal. If not then move to a professional spot remover as soon as possible.
#850
Former Vendor
I keep a small bottle of rinseless wash and a bottle of bugsquash along with several MF towels in a ziplock in each car. When traveling I immediately remove sprinklers, buggies, and doo-doo. Prepare in advance and keep something on hand.
#852
Former Vendor
Remember to clean those headlamps and consider sealing them for long term protection even when hidden in the bumper.
#853
The Meguires Waterspot remover package, conveniently, has a photo of a lawn sprinkler on the label!
#854
So I have a question... I'm still a bit confused about all the products...
I have a 2012 GS Centennial Edition. I just purchase a PC DA polisher with a couple of orange pad and a couple of white pads from AutoGeek.
I plan to wash the car (foam cannon) and then clay with Mothers clay using their quick detail spray as a lubricant.
Next -- I have some Meguiar's clear coat polishing compound, SwirlX swirl remover and NXT Tech wax 2.0.
What is the proper sequence?? Swirl remover, polishing compound, wax?? OR Polishing compound, swirl remover, wax??
Also, I have polishing COMPOUND but I keep reading that I should use finishing polish after the swirl remover... are they the same thing??
Thanks in advance for the help.
acheman8 is offline
acheman8 is offline
#855
Hot DA backing plate Issues
I'm currently using a Griot's that has about 50 hours on it. When using the machine I don't press down but let the machine do most the work on horizontal surfaces. I am now experiencing the center of the backing plate getting so hot it is actually melting the black Velcro off the pad in about a 1 1/4 inch perfect circle. I am very experienced with polishers and always make a point not to hold it where the fan and other vents are covered. I have also melted the black Velcro to where it wrinkles on two backing plates. Putting two fiber washers on the mounting stud hoping it would insulate the backing plate but no difference. The counterweights and visible parts seem fine, nothing impeding the DA orbit. It seems the worst when using an orange CCS 5.5 pad with SIP Menzerna but it's almost as bad with the white pad. Do you have any idea what might be going on?
#856
I've been watching and learning from your site but I have a question on steps and products. Background: 78 pace car original paint pretty nice some imperfections
1) wash
2) clay ill buy meguires
3) swirl remover ( what is that and what should I use) ??
4) Polish already have meguires
5) carnuaba already have meguires. Thanks for any help you could provide.
Can I clay over the decals on the doors, ect???
1) wash
#857
Former Vendor
1) wash
1) wash
I do not clay on decals. I also try not to polish them. Generally you should follow the manufacturers directions to keep your decals for as long as possible. Chemical Guys makes a product to protect decals.
#858
Ok, here's one for you.
I have been cleaning/detailing my own cars for a long time, since I was like 15. So 15 years give or take.
My current daily driver, and my wife's DD both have light tan colored carpets. We have a 2 year old and a 5 year old.
I have been vacuuming and steam cleaning them every so often, then putting down 3M scotchgard, which works pretty well but doesn't seem to last very long (the instructions say to reapply every 3 months, which will never happen I just don't have the time).
So I know there are other products out there that work like scotchgard, to protect your carpet and upholstery. What are the best/longest lasting ones and they have to come in a gallon size. I'm so tired of having to buy a crap load of the cans to spray with. I have a 5hp 60 gallon air compressor so I can spray them with that it needed.
#859
Former Vendor
This is a product that cleans and protects and comes in a gallon as requested. So far testing is good. Stoners, 303, Chemical Guys and others exist also. Some might not be available in gallon sizes but can be sold in bulk as desired.
#860
I have a metallic red car that has a slight scratch and was wondering which product to use to fill in the scratch . I can feel it with my fingernail
Clif
Clif
