Ask the Autogeek! Question & Answer Thread
#881
2017 Corvette of Year Finalist
2016 C5 of the Year
Ok cool, if you ever do just let me now. I have bought a lot of stuff from you guys and always liked everything I got. Thanks for answering my question.
#882
Former Vendor
If there is a product line you like, it best to drop us a line. We listen and try to test and sample the lines in order to keep our site offering the products wanted by our clients. We appreciate your suggestion.
#883
Coating question
I recently applied a Duragloss ceramic coating to my car, and I am very happy with the results. I usually clay-bar the car about twice a year. Will the finish still require clay since it is coated? Will clay remove the coating?
Thanks for your help. I'm a big fan of Autogeek; it's like Christmas Day whenever a shipment arrives.
#884
Former Vendor
Remember the plastic bag trick and no need to over clay. I suspect you may now move to one claying annually unless the automobile is in an environment of heavy dirt and pollution.
#885
I just took delivery of a 2015 Arctic White Vert (Corvette). Will do the sandwich bag test to see if there is a need for clay bar and polish.
What I am looking for is a wax or sealant that will really make the Arctic white pop. In the past I have used Rejex, Megs products, Dodo red, etc. ready to move on.
Suggestions please.
Also do I need anything to keep the top looking new.
Suggestions please.
#886
Former Vendor
Suggestions please.
Suggestions please.
Enjoying one of the best rides for 2015 also means its time to move from old waxes and sealants to the newest offering a coating. Don't worry you will have longer protection and easier application.
I would do the same as any new ride. I would do a good wash, consider Iron-X to remove any metal particles, a light clay as needed, some polishing as needed .... and application of Opti-gloss or G-technics ceramic coating. Application is simple, apply to a clean wax free surface and buff off any high spots (over application). One coat, thin is in, and not a lot of overlapping needed.
Coatings will make white look like glass, with lots of reflection and gloss.
#888
Former Vendor
I too have seen posts elsewhere that suggested it was used without issue. I tend to error on the side of caution and with such an expensive brake option would consider simple soap and water when possible. I might coat the wheels also to help keep them easy to clean with soap/water.
#889
I am getting ready to purchase a 12 Grand Sport coupe color Cyber Gray metallic. This is my first vette and would like any suggestions on a starter kit for polishing and cleaning the car. I have been looking at the PC 7424XP but not familar with all the pad choices. Do you offer something for the newbie. Thanks in advance.
Jim
Jim
#890
Former Vendor
Jim
Jim
Menzerna Polishes
Four Star UPP (sealant)
Blackfire Spray Sealant
EZ Wheel Brush
Hydro-tech pads from Lake Country
Griots or DP or P21S Wheel Cleaner
#891
I bought the Meguairs DA system from you Autogeek and washed, clayed and then went to town on the car. I was kind of disappointed with the results thinking that it was going to be more aggressive than the 7inch maroon foam pad. I still have hard water etchings that won't come out. I read that the clearcoat is really hard on these cars and i've obviously verified that I made sure to do slow passes and all...what should be my next step? I thought about buying the thinner 5inch pad for more cut but i'm doubting that will do much more. Looking forward to a response.
Thanks in advance
Thanks in advance
#892
Former Vendor
Thanks in advance
Thanks in advance
#893
Moldy mildew stain on Tan fabric convertible top won't budge
I have tried numerous products and just tried 303 Convertible Fabric top cleaning and care kit after seeing the tutorial on your site. My order got here in 2 days...wow. But no luck. Unless you have another idea for removing these stains - Please indicate a Dye product that has been successful. I see a lot on the internet/youtube. I need help. The Tan top is in great shape but really stained by mold/mildew.I need your help because I don't know what to do. Maybe go to a Marine upholstery shop???
#894
What would be a good wax to use on a black daily driver sport utility that will not dry white in the nooks and crannies? The vehicle is garaged and highly detailed at least once a year.
#895
Former Vendor
I would apply the cleaner outside of direct sunlight and allow to dwell for 5-10 minutes. Reapply the spray as needed to keep top damp. I would then use a soft brush and scrub those areas. I would then wash off and dry the roof as possible. I would then move to the protectant only once the roof is in the condition as needed.
#896
Former Vendor
If the finish is in good condition and detailed well, I would consider a sealant or coating. Four Star UPP and Blackfire Sealants are both easy to apply and remove and look absolutely incredible on black paint. Both can also be topped with numerous sprays and boosters without issue thru-out the year as wanted/needed. You should not see any white trim or cracks as these products have no cleaners no abrasive polishes in them.
#897
Detail Help
Bought a White 2009 convertible. Going to buy the 303 convertible care kit. Paint looks good only a few light scratches on trunk and a faint amount of swirl marks on the car. Was thinking of buying the Girot's 6 inch orbital, Meguire's SwirlX, Ultimate Polish, Ultimate Liquid Wax and a few Cobra MF towels. I have never used an orbital polisher before. Any suggestions regarding products would be greatly appreciated.
BTW- I am going to purchase from Autogeek
#898
Former Vendor
#899
What would you recommend to remove small linear scratches in my stock stainless exhaust tips on my new Z06? I could try the 0000 wool w/ some mother's metal polish perhaps, but wasn't sure if that would get these scratches out or not. Thanks for the advice in advance.
#900
Former Vendor
stainless steel is quite durable and scratches are often hard to remove without use of buffing wheels and polishes. I too would try the steel or brass wool in quad zero and test on a small area in case it makes the outcome less than desired.
