Ask the Autogeek! Question & Answer Thread
#921
New aluminum wheels
I purchased new aftermarket aluminum wheels for my 78 Pace Car. I just had new tires mounted on them and when I picked them up they were sitting out in the sun to dry. The installer had cleaned the blue protection from the raised white letters for me. I took them home and put them in the garage without drying them. This was on a Friday. On Sunday I wanted to polish the barrels to protect them prior to putting them on the car and noticed that there were water spots all over them. I applied Mothers chrome polish (I thought they were chrome) and the spots did not come off. A friend stopped by and said to try aluminim wheel polish on another wheel so I did with the same results. Yesterday, (Monday) I took Dawn detergent and washed all 4 wheels and tires and dried them. I still have water spots on otherwise clean and shiney wheels. I've read a few post here in the forum to use such items as Z-A10, Groits, or clay bar to clean clear coated aluminum wheels. I've also read to remove the clear coat and then seal the wheels for easier cleaning over time. What would you suggest?
#922
Former Vendor
The water-spots sure seem stubborn as you got to them quite quickly. It sounds like you have some serious minerals or hard water and the sun baked it in. I too might suggest using a paint polish or paint cleaner "if" the wheels are clearcoated. Do it outside of the sun, when the wheels are cool. Once cleaned up and spot free, get a couple good coats of a sealant on them, or preferably a coating as possible.
#924
Former Vendor
http://www.autogeek.net/optimum-carpet-cleaner.html
#925
When polishing aluminum with a product like Mother's Aluminum Polish or Billet Polish when should the foam pad be changed or cleaned? I do a lot of aluminum polishing and found after a few passes the foam pad is black and beginning to smear the black residue on the polish surface. Thanks
#926
Former Vendor
My personal preference was to keep sections small, polish, and then try to remove/wipe the black stuff off to avoid recontaminating the applicator and pads. It certainly was not an exact science. Even soaking the towels in a heavy citrus cleaner, you could not remove all that darn black tarnish also.
If you find some interesting hints , please share with us.
#927
When I polished my uncoated wheels, I found that I went thru a lot of towels and several pads. I also found the wool bobs and other items blackened quickly with all the tarnish.
Sometime using a quick detailer and wiping the part frequently seems to have the most affect. If you use MF towels to wipe the reside off just be prepared to either live with them with the black residue stain or just discard them. The black residue will not come out no matter what us use to wash them with. It is a dirty job and no way that I have found to keep anything clean during the polishing process. Maybe someone else has some ideas.
#928
2017 Corvette of Year Finalist
2016 C5 of the Year
Is there such a products to help keep brake dust off the wheels? I have powder coated wheels and just have always put polish and wax on them, seems to go alright. just didnt know if thier was anything better?
#929
Former Vendor
A modern coating, usually quartz or ceramic, will protect wheels (and barrels if applied) for a year or longer with one application. They wont stop brake dust, but cleanup is easier. You may also want to consider ceramic brake pads which reduce dust and its appearance. Together its a great one, two punch.
http://www.autogeek.net/gtechniq-c5-wheel-armor.html
http://www.autogeek.net/pinnacle-wheel-coating.html
http://www.autogeek.net/cquartz-dlux.html
#931
Former Vendor
You should do a series of items:
1. Wash paint well, consider also using Iron-X or Decontamination kit from Finishkare
2. Clay or Clay Sponge
3. Use a paint cleansing lotion
4. Polish paint using a variety of polishes and pads
5. Protect well and try to keep car outside of future contamination environment
#933
Former Vendor
Many other wheel "coatings" now exist, and we also offer one within the Pinnacle Black Label Line. Coatings long outlast sealants and waxes.
http://www.autogeek.net/car-paint-gl...-coatings.html
#935
Former Vendor
I doubt the wheel cleaner your using will remove all of a well cured sealant, but it could likely reduce its protection. Since its so easy to apply, why not add some more Rejex afterwards ??
#936
Rejex is a pretty durable sealant ... that said, once a wheel is sealed or coated, all you should need is some soap and water to clean them. If you feel that the protection is falling off, then use a wheel cleaner. I would then, personally, add a new coat of the product of my choice.
#937
I've been using Zaino for over ten years. I have been looking at coatings for the last six months. Just when I had it narrowed down to two, you all go and release the WG Uber Coating. Just ordered that kit along with Uber compound and finishing glaze. I don't see a WG specific booster, any plans for one or should I go with Pinnacle Black Label booster or Reload?
Thanks!
Thanks!
#938
Former Vendor
Thanks!
Thanks!
ronkh57 (10-29-2015)
#939
TMI
I want a safe easy to use product to get out swirl marks on the black c6 I now have .
I have a Portacable 7424xp and 3 different pads . (On order from wife Christmas gift )
Now I need to order a product ?
I called maguiiars they said to use Ultimate compound .
Others here say m105m m205
Information over load doing search on what to use .
Please recomened something easy to use that I won't mess up my paint.
