Pinnacle liquid Souveran question...
I will be applying this to my white C6. I will not be using a sealant. Will the liquid Souveran last a month? I plan on waxing the car every 4 weeks.
St. Jude Donor '09
The durability is about the same in Texas heat, which is very short btw.......
Here is a recent thread about the two products you may find interesting.....
http://www.autopia.org/forum/car-det...liquid+souvern
Former Vendor
It is funny to find these complaints on the durability of Pinnacle Waxes and yet its always considered the best of the waxes and the one to beat. If used correctly, you will see 4-6 weeks of protection minimum. That means using a soap compatible with carnaubas (not sealants which are stronger not necessarily better in protection). If you consider the Pinnacle Soap you will see a marked difference in durability.
To add additional durability use the correct detail sprays also versus some designed for sealants waxes... Pinnacle designed Crystal Mist and Souveran Spray Wax for just that.
Using Souveran Paste, Pinnacle Soap, and Souveran Spray Wax I had over 8 weeks of protection and actually recoated before the beading and other indicators wore off. This was done on a daily driver not a garage queen and in Floridas heat and humidity.
Liquid Souveran is indeed more durable than the Paste version, at least in my private uses. I however find Souveran Paste to look much better and super easy to apply and remove. Adding a coat on a Vette literally takes 10 minutes. The formulas are completely different and the LS is designed to be coated and dried before removed while paste is WOWO>
Also, is there any other soaps that are a bit easier on the pocket other than Pinnacle, yet still work well with carnaubas?
Lastly, I plan to wax every four weeks with LS. I use optimum detail spray only after each wash once a week. I know optimum QD won't add protection like the Souveran spray wax or Crystal mist, but it won't breakdown the Liquid Souveran, will it? This is a very important question.
I'm going to try Mother's Gold over the Megs Gold. The Megs Gold supposedly has a conditioner in the soap. Te me, that sounds like something extra added to the soap, but all I want is soap.
