Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Best auto glass cleaner
Old 11-12-2014, 10:04 PM
Vettlldo
Vettlldo's Avatar
Originally Posted by Comfortably Numb
It is not the cleaners fault. It is the towel you are using. Try these and you'll get your windows clean www.ultimatecloth.com
I purchased this cloth but despite following their instructions it still left streaks on my windows..until I learned this trick. Lightly dampen the Ultimate cloth as recommended but wipe the window surface first with a clean, damp cotton towel. I no longer have streaks on my windows.
Old 11-13-2014, 04:50 PM
Merlinii
Merlinii's Avatar
I have used Sprayway Glass Cleaner for "many" years and it's my favorite glass cleaner spray.
Recently I've been using Fast Glass Towels. No glass cleaners and no streaking. I'm Very Happy!
Old 11-14-2014, 04:32 PM
JRE-C6
JRE-C6's Avatar
Griots window cleaner...We have used this on our Pebble Beach 1st place winners! It is a very good product.
Old 11-19-2014, 08:13 PM
petsur
petsur's Avatar
Have you used newspaper?
Old 11-22-2014, 11:41 PM
leebay
leebay's Avatar
Default Glass Cleaner
Stoners and large commercial coffee filters !
Old 12-26-2014, 04:57 PM
WetteVette
WetteVette's Avatar
Originally Posted by DsC5
Stoners Invisible Glass and a microfiber towel.
However, I have found that the towel is more important than the cleaner.
Old 12-29-2014, 02:50 AM
Grzldvt1
Grzldvt1's Avatar
Go to your local Big Box or local hardware store that carries Zep products and buy the glass cleaner. The one and only time I will say the warehouse towels work is on glass. Zep Glass Cleaner and a MF towel will do the trick.
Old 12-29-2014, 10:25 AM
bigcypress
bigcypress's Avatar
. . .cleans with plain water, it removes film, dirt, oil, grease, finger prints, dog nose prints, etc all without the use of chemicals, for severe out gassing or the removal of stubborn grime; spray the glass surface (otherwise you are using a diluted cleaner that will not cut through grease and etc) with a 1:10 solution distilled water /Isopropyl alcohol and wipe with a clean CorsaCloth and the result is a crystal clear finish.
excuse me sir but isn't your ratio backward .......i'd think one alcohol to ten water . . .peace........edit , i like stoners . can't figure out why you can't use the ''outside stoners'' on the inside .
Old 01-04-2015, 09:58 AM
bigblock427
bigblock427's Avatar
Received 1,346 Likes on 1,057 Posts
I have used Adam's Glass Cleaner and their glass cleaning micro fiber (green color) towel for years. This combination of products does an absolutely outstanding job of cleaning glass without any leaving any streaks or scratches.
http://adamspolishes.com/shop/adam-s-glass-cleaner.html
http://adamspolishes.com/shop/interi...ant-combo.html
Old 01-08-2015, 02:27 AM
skxf430
skxf430's Avatar
Sprayway with a clean micofiber works really well. I find Sprayway to be vastly better than Stoners.
Old 01-10-2015, 08:10 AM
KBsToy
KBsToy's Avatar
Originally Posted by Killrwheels@Autogeek
Stoners Invisible Glass, Sprayway Glass Cleaner, and NXT's Glass Cleaners are all great options. I do believe the WW MF towel design helps tremendously and glass cleaning needs to be done outside of direct sunlight for best results.
A Glass Wizard is a nice option for front glass on C5/C6 Vettes to get into low areas like the area under the HUD display.
Quick Reply: Best auto glass cleaner
