Best auto glass cleaner
It is not the cleaners fault. It is the towel you are using. Try these and you'll get your windows clean www.ultimatecloth.com
I have used Sprayway Glass Cleaner for "many" years and it's my favorite glass cleaner spray.
Recently I've been using Fast Glass Towels. No glass cleaners and no streaking. I'm Very Happy!
Have you used newspaper?
Glass Cleaner
Stoners and large commercial coffee filters !
Go to your local Big Box or local hardware store that carries Zep products and buy the glass cleaner. The one and only time I will say the warehouse towels work is on glass. Zep Glass Cleaner and a MF towel will do the trick.
. . .cleans with plain water, it removes film, dirt, oil, grease, finger prints, dog nose prints, etc all without the use of chemicals, for severe out gassing or the removal of stubborn grime; spray the glass surface (otherwise you are using a diluted cleaner that will not cut through grease and etc) with a 1:10 solution distilled water /Isopropyl alcohol and wipe with a clean CorsaCloth and the result is a crystal clear finish.
excuse me sir but isn't your ratio backward .......i'd think one alcohol to ten water . . .peace........edit , i like stoners . can't figure out why you can't use the ''outside stoners'' on the inside .
I have used Adam's Glass Cleaner and their glass cleaning micro fiber (green color) towel for years. This combination of products does an absolutely outstanding job of cleaning glass without any leaving any streaks or scratches.
http://adamspolishes.com/shop/adam-s-glass-cleaner.html
http://adamspolishes.com/shop/interi...ant-combo.html
Stoners Invisible Glass, Sprayway Glass Cleaner, and NXT's Glass Cleaners are all great options. I do believe the WW MF towel design helps tremendously and glass cleaning needs to be done outside of direct sunlight for best results.
A Glass Wizard is a nice option for front glass on C5/C6 Vettes to get into low areas like the area under the HUD display.
