clay vs. windshield water spots
Clay bar will take allot of surface contamination off of various surfaces. Try it and see if it works on your water spots. If it doesn't work get a little more aggressive. I know that AutoGeek has some great products just for glass. Contact them if the clay bar doesn't work.
Former Vendor
Greg @ DI
Former Vendor
Clay works great on water spots. I had some spots on my boat windshield from the Mississippi that I could not get off. Scrubbed glass with Stoners and could not get rid of them. I clayed the windshield and it looked like new.
If the clay method fails, try using 4 "OOOO" steel wool, with a very fine cleaner polish, Meguiar's M80 works well. Test in a small area first to make sure you are getting the desired results.
I have also used Meguiar's #47 religiously on my Eliminator Boat which is a dark purple gelcoat on the transom to combat hard water spots. It works fabulous, spray on....allow 20-30 sec dwell time and then wipe off. For windows I would do the same, then clean with a premuim window cleaner.
http://marinerv.meguiars.com/product...r-Spot-Remover
Dave @ Innovative Detailing
