Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
NEW Porter Cable 7424XP RV/Marine Detailing Machine At ProperAutoCare.com
Old 04-15-2010, 11:58 AM
0zoomzoom mazda5@properautocare.com
Former Vendor
zoomzoom mazda5@properautocare.com's Avatar
Default NEW Porter Cable 7424XP RV/Marine Detailing Machine At ProperAutoCare.com
Porter Cable 7424XP RV/Marine Detailing Package.
Our 7424XP RV/Marine Detailing Package is built around the new, more powerful, Porter Cable 7424XP polisher. This machine incorporates a random, swirl-free polishing action that will not scratch your boat's gel coat finish. An electronic variable speed control allows you to adjust the speed from 2,500 to 6,800 OPM. A heavy duty, 4.5 amp motor supplies plenty of torque and the machine is double insulated against shock. (Obviously this is a 120 volt polisher and not to be used while the boat is in the water!) The hand grip can be screwed into either side making the polisher adaptable for right or left handed operators.
Tech Note: Within the industry, this polisher is classified as an orbital polisher. It is designed to safely apply compounds, polish and wax in a manner similar to hand application. It creates a mirror-like finish and shine in a fraction of the time it would take by hand. It will not create swirls or remove your RV/boat's gel coat finish.
The pad does not rotate in the conventional sense, it oscillates. This "jiggling" occurs at such a high rate that the eye can not see any pad movement. This is normal. This is the way the polisher is designed to work. This polisher is not designed for heavy compounding and may not fully restore gloss to dull gel coats. To restore gloss to moderate to severely oxidized (dull) gel coats, consider a professional, circular polisher such as the Makita 9227, or DeWalt 849 .
This 7424XP RV/Marine Detailing Machine is best used to maintain new RV/boats and/or gel coats in good condition.
This kit is designed for standard or painted gel coat finishes. We do not include any compound, polish, wax or sealant in this kit allowing you to use your favorite products. We do include a Bow to Stern Application guide. If you follow the instructions in this guide, you should be able to compound, polish and seal any marine or RV gel coat finish using your favorite products.
This kit includes one Gel Coat Orange Power Pad for polishing and three different pads for finishing. Most pure waxes and sealants apply best with a Red Finishing Pad. Some combination polish/sealants like Klasse All-in-One apply best with a White Polishing Pad while other polish/sealants, like Bow to Stern One-step, Gel Coat Micro-polish & Sealant apply best with a Gel Coat Orange Power Pad. We include a Red, White and Orange Gel Coat, CCS Technology Foam pad in this kit so you will have the correct finishing pad regardless of the final wax or sealant used.
Our 7424 Marine Detailing Kit contains:
Porter Cable 7424XP Machine Polisher
6 inch Flexible Hook-and-Loop Backing Plate.
Two (2) 7-1/2 inch, CCS, Gel Coat Orange Power Pads. (one pad for polishing and one pad for the final polish/sealant if required)
One (1) 7-1/2 inch, CCS, Gel Coat White Polishing Pad. (for applying some polish/sealants)
One (1) 7-1/2 inch, CCS, Gel Coat Red Finishing Pad. (for applying liquid waxes and marine sealants)
One (1) 32 oz. Bow to Stern All Marine Cleaner
One (1) 16 oz. Pad Lubricant & Residue Remover
1 Pkg/3 Snappy Clean Pad Cleaner Packets
Four (4) Power Scrubber Applicator Pads
Three (3) Microfiber Buffing Cloths
Bow to Stern Application Guide
Pad Care: Spray dirty foam pads with Bow to Stern All Marine Cleaner and soak in a bucket of water with a packet of Snappy Clean Pad Cleaner. Let pads soak for 5 to 15 minutes. Fluff up pad with your fingers then hand squeeze out excess water. Allow to air dry, preferably in the sun. Do not use pads still wet from cleaning.
Angelo
www.ProperAutoCare.com
800-628-7596
Quick Reply: NEW Porter Cable 7424XP RV/Marine Detailing Machine At ProperAutoCare.com
