New Meguiar's Motorcycle Products From ProperAutoCare.com
Former Vendor
Meguiar's Motorcycle EZ Clean Spray & Rinse makes it easy to clean every nook and cranny of your motorcycle quickly and easily. Meguiar's EZ Clean Spray & Rinse was formulated to lift dirt and grime without scrubbing.
Simply spray Meguiar's EZ Clean Spray & Rinse on all areas of your motorcycle. The Xtreme Cling™ foam is designed to cling even to vertical surfaces to promote better cleaning. Allow the cleaning foam to penetrate dirt and grime for 15 - 30 seconds. Rinse the area with water to reveal and sparkling shine.
Meguiar's EZ Clean Spray & Rinse makes cleaning your motorcycle easy with ph balanced, biodegradable ingredients. You can safely use Meguiar's EZ Clean Spray & Rinse to quickly and regularly clean your motorcycle.
________________________________________ ________________________________________ ______________________
Meguiar's Motorcycle Detailer Mist & Wipe makes allows you more time on your motorcycle and less time cleaning it. Use Meguiar's Motorcycle Detailer Mist & Wipe on the go, or after an evening ride. The compact 8 ounce size makes it convenient to take Meguiar's Motorcycle Detailer Mist & Wipe wherever you go.
When your motorcycle is hit by a surprise attack of bugs, rain, bird droppings, or other environmental hazards, a quick spray and wipe will quickly remove those contaminants and prepare you for your next outing. The safe formula loosens dirt and grime with one spray making them easy to wipe away with a microfiber towel. Use Meguiar's Motorcycle Detailer Mist & Wipe to restore and rejuvenate your current wax or sealant product.
Meguiar's Motorcycle Liquid Wax Wet Look is the easiest way to clean, polish, and protect all your motorcycle's paint, chrome, and aluminum finishes. Meguiar's Motorcycle Liquid Wax Wet Look makes the process easy by combining 2 steps into one easy to use product.
Meguiar's Motorcycle Liquid Wax Wet Look combines a non-abrasive cleaning polish that safely removes fine scratches, swirls, and contaminants with a protective layer that makes your motorcycle's paint look deeper and clearer. Meguiar's Motorcycle Liquid Wax Wet Look will protect your paint against road grime, bug splatter, and other pollutants that can damage unprotected paint.
Meguiar's Motorcycle Leather Clean/Conditioner cleans and protects your motorcycles leather and vinyl in one easy application. With a premium blend of nutrients and moisturizers, Meguiar's Motorcycle Leather Clean/Conditioner leaves leather and vinyl looking and feeling supple.
Meguiar's Motorcycle Leather Clean/Conditioner's gentle formula effectively cleans, restores, and enriches leather and vinyl. It also helps prevent premature wear, such as drying and fading without leaving slippery surface or artificial gloss.
Use Meguiar's Motorcycle Leather Clean/Conditioner on saddle bags, seats, and all other vinyl and leather surfaces to protect and moisturize.
Use Meguiar's Motorcycle All Metal Polish to shine all your motorcycle's metal parts to a bright, clear reflection. Meguiar's Motorcycle All Metal Polish is not a strong smelling, harsh chemical. It cleans oxidized metal surfaces to a mirror-like reflection while emanating a pleasant, non-irritating scent.
Meguiar's Motorcycle All Metal Polish is a soft paste for easy application to all metal surfaces. Apply it with a soft cloth or applicator pad rubbing until the surface looks clean. Buff with another soft microfiber cloth to a mirror finish.
Meguiar's Motorcycle All Metal Polish is not for use on gold plating, anodized metals, painted or clear coated aluminum wheels.
Restore clarity to clear plastics with Meguiar's Motorcycle Plastic Polish. Easily remove fine scratches, surface stains, and light oxidation with Meguiar's micro-abrasive technology. Use Meguiar's Motorcycle Plastic Polish on motorcycle windscreens, helmet visors, and plastic instrument panels to restore optical clarity.
Meguiar's Motorcycle Plastic Polish also conditions clear plastics leaving a water-resistant polymers to provide long-lasting durable protection.
Angelo
www.ProperAutoCare.com
800-628-7596
Angelo
800-628-7596
