Dark cars & spray wax?
Just tried to wax the wife's dark blue Ford Exploer today and i tried the Mcguire's, Turtle, Eagle one, Armor all, there all spray waxes! and i use microfiber towels and i still get alot of streaking, suggestions please.
Here are my suggestions/tips:
#1-When using a spray wax/detailer spray/waterless wash, if the car has not been taken care of in the past and has a rougher finish, has not been recently waxed or needs to be clayed, the results will not be as good.
#2-Make sure the cloth/microfiber is clean before using it for a spray wax. If you have anything else on it, it could cause problems.
#3-Pay attention to the temperature/humidity leval. If the spray wax dries to quickly, it'll streak. If it's really humid, it'll take longer to dry and need extra wiping.
#4-Don't get a dark colored vehicle.
#5--Don't use too much.
I'm no pro-just throwing some ideas out there.
Here's a trick I use at shows. After you do the spray thing, whether it be wax or QD, take a spray bottle with clean water and lightly spray down a section, removing it with a MF towel. Any streaking will disappear.
Good Luck
Good Luck
This could get complicated.... Car Care Forum can help, but til then
Wash all that spray wax using Dawn
Probably need "claying"....Car care can explain that
Spray wax lightly and wipe quickly
Water spray was a good idea
Buff w/microfiber
Buff w/microfiber
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Too late.
I'm using Turtle wax Black Box on mine. You use the included detailing spray while removing the liquid wax.
Hard to tell now but the entire front end and all four fenders behind the tires show the cars history as an autox and HPDE car.
Received 1,681 Likes
There's a really nice car care section here on the forum!
Received 4,578 Likes
2016 C2 of Year
2015 C3 of Year Finalist
Especially with darker colors:
Try to avoid spray detailing in direct sunlight or when the surface of the car is warm or hot.
Don't get too greedy trying to cover a larger area than you can quickly buff.
Keep rapidly flipping the microfiber to the dry side to get it buffed off quickly.
Former Vendor
It could be a few thing's like; Washing your towels in a strong detergent, drying them with dryer sheets, using too much spray wax, the temperature/humidity could be the problem, poor quality towel. A number of factor's can play in that roll.
I'll be the first to tell you, w/o mentioning the specific spray waxes your using its hard to determine what the issues might be.
Generally most spray waxes available at auto stores are not true stand alone spray waxes these are mainly designed to freshen an existing coat of wax, so when there isnt wax it just ends up streaking all over your paint.
Some stand alone spray waxes that you can buy locally are Duragloss aquawax, Meguiars Ultimate quick wax, Lucas Speed bead these will probably apply better and not streak.
Another issue is if your out in the sun you want to do smaller sections, i.e. divide your hood into six parts, and use very little dont try to saturate the whole area until its dripping.
Former Vendor
The Final Wipe – Tips for creating a streak-free, show car finish
You are correct in that most spray waxes are not and should not be used as a "Stand Alone" or "Dedicated" wax product, some are however.
Anytime you have to work in the sun or in warm temperatures it's a great idea to
- Shrink the size of your work area down
- Work in the early morning when it's going to be the coolest outside
The most important factor is the paint needs to be washed, clayed, and perfectly smooth and clean just like paint should be before using a "Finishing Wax" (or paint sealant).
Then, mist a little on to a small section, spread the product around using a clean, folded microfiber towel, then either turn to a dry side and wipe the residue off or allow the product to dry to a haze and then wipe-off using a clean, folded microfiber towel.
Spray waxes are easy to use if the paint is in "Excellent" condition to start with. If the paint needs any kind of claying, cleaning or polishing, or has not been regularly maintained or recently waxed then getting GREAT performance out of any spray wax will become more difficult.
