Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
An "Ooops" with Microfiber Towels
Old 08-31-2010, 11:32 AM
vettluver
vettluver's Avatar
Default An "Ooops" with Microfiber Towels
Long story cut short...my Cobra Lavender microfiber towels ended up in the dryer on low heat setting with a bounce sheet. When I found them, I took them out, rewashed in the machine them with DP microfiber cleaner and dried them again on low heat in the dryer. Is one cycle through the dryer with a bounce sheet enough to ruin the towels?
Thanks in advance for your opinions.
Old 08-31-2010, 12:51 PM
Grzldvt1
Grzldvt1's Avatar
You should be fine. The dryer sheets release a chemical that reduces static and softens the towel, but it is not permanent. A wash should get rid of everything, a second wash would not be a bad idea just for your own peace of mind.
Old 08-31-2010, 02:03 PM
KBsToy
KBsToy's Avatar
Wash again with micro-fiber detergent.
Old 08-31-2010, 06:54 PM
0Killrwheels@Autogeek
Former Vendor
Killrwheels@Autogeek's Avatar
If you find they dont seem as absorbent as prior, consider a rewash and add some white vinegar in the rinse cycle. Should remove any residual softner from those sheets.
Old 09-01-2010, 01:17 AM
vettluver
vettluver's Avatar
Thanks everyone for your input.
Old 09-08-2010, 10:51 PM
SSTEVEGS
SSTEVEGS's Avatar
...and throw out all those "chemical relasing" bounce sheets! My mom used to use them on my clothes when I was a kid and I'd get horrific headeaches until we discovered the dryer sheets were the culprit.
To An "Ooops" with Microfiber Towels
Quick Reply: An "Ooops" with Microfiber Towels
