Help with zanio or claybar in general
So I got a late start today and after washing and claybaring my car I lost daylight and only had time to dry it. Tomorrow I was planing on washing with the zanio wash and start waxing. I live in an area where there is a lot of construction and dust. Will this be a problem to wait to wax overnight after claying? Reading the zanio instructions it says to wax right away but I'm thinking I should be fine after a wash. any thoughts?
Thanks, thought so but wanted to be sure. Also, I bought just about every zanio product for my black c6. ;-) Tomorrow the plan is to put only one coat of initial wax as time is limited then build from there. The car is stripped of wax two washes of dawn and claybar. I planned on using the z-5pro and following up with z-cs for the first coat. I think I read you should use zfx on first coat but I know its not needed just for following up with z-cs. Anyone?
As long as your finish is clean before you Zaino it you will be fine.
You do not want to wipe or Zaino/wax a dusty or dirty finish as the dust will scratch the finish.
