New Meguiar's Products Now In Stock At ProperAutoCare.com
Former Vendor
New Meguiar's Products For 2011
Meguiar's G3000 Heavy Duty Headlight Restoration Kit
If you've been driving with faded or yellowed headlight lenses, you are have been living dangerously. Get rid of those yellowed lenses with Meguiar's Heavy Duty Headlight Restoration Kit. This kit is a complete sanding and polishing system guaranteed to brighten up those cloudy headlights.
Meguiar's Heavy Duty Headlight Restoration Kit restores clarity to severely neglected, oxidized, yellowed, and scratched headlight lenses. The kit uses sanding discs for heavy oxidation, yellowing, and scratch removal, a drill attachment with Plastx to quickly restore optical clarity, and a protectant to keep the headlights clean and clear and protected from UV rays.
The kit includes:
* 1 - Cushioned sanding pad
* 1 - 1000 grit sanding disc
* 1 - 3000 grit sanding disc
* 1 - Easy Buff™ drill-mount pad
* 1 - 4oz Meguiar's Plastx
* 1 - 4oz Meguiar's Headlight Protectant
* 1 - 16" x 16" Meguiar's microfiber towel
This is basically a 3 step headlight restoration system: 1: Sand; 2: Buff; 3: Protect. This kit will easily restore a pair of headlights. But it will do more than just headlights. Use Meguiar's Heavy Duty Headlight Restoration Kit on boat windows, motorcycle wind screens, taillights, and more!
Don't replace your yellowed, scratched and oxidized lenses. Restore them with Meguiar's Headlight Restoration Kit and save money.
________________________________________ ________________________
Meguiar's G3200 Brilliant Solutions New Car Kit
Meguiar's has precisely selected products to give you maximum results from one package. Meguiar's Brilliant Solutions New Car Kit eliminates the guesswork and puts together the basic components to keep your car looking new. This Meguiar's New Car Kit covers the exterior including your tires in 3 easy steps.
The kit includes:
* 1 - 16oz Meguiar's Ultimate Wash & Wax
* 1 - Meguiar's Microfiber Wash Mitt
* 1 - Meguiar's Water Magnet Drying Towel
* 1 - 6oz Meguiar's Ultimate Liquid Wax
* 2 - Meguiar's Soft Foam Applicator Pads
* 1 - Meguiar's Supreme Shine Microfiber Towel
* 1 - 6oz Meguiar's Endurance Tire Gel
Meguiar's New Car Kit isn't just for new cars. Keep your almost-new car looking good with this kit, too! Just use the 3 easy step method outlined on this kit. First wash & dry with Ultimate Wash & Wax, the microfiber mitt, and the Water Magnet Drying Towel.
Step two is wax and protect with the liquid wax, applicator pad, and the microfiber towel. The third step is making your tires shine using the tire gel applied with an included applicator pad.
Meguiar's makes it easy to keep your new car or your slightly used car looking showroom sharp.
Meguiar's G3300 Brilliant Solutions Paint Restoration Kit
Meguiar's has created the Meguiar's Brilliant Solutions Paint Restoration Kit that gives your slightly used car's paint new life. The Meguiar's Paint Restoration Kit brings 4 easy paint detailing steps together in a hard to beat package that has everything you need for the job.
The kit includes:
* 1 - 16oz Meguiar's Gold Class Car Wash
* 1 - 50gr Meguiar's Smooth Surface Clay Bar
* 1 - 10oz Meguiar's Quik Detailer
* 1 - 10oz Meguiar's Ultimate Compound
* 1 - 6oz Meguiar's Gold Class Carnauba Wax
* 2 - 16" x 16" Meguiar's microfiber towels
The steps are wash, clay, prep, and wax. The Meguiar's Paint Restoration Kit has the products you need to bring back neglected, dull, oxidized paint and make it look showroom new.
After washing your car with Meguiar's Gold Class Car Wash use the Meguiar's Clay Bar and Meguiar's Quik Detailer to remove contamination from your paint to get a super smooth surface. Follow that with Meguiar's Ultimate Compound to improve your paint's clarity and gloss and remove oxidation, scratches, and swirls. The compound also removes stains and other defects that are below the surface of the paint.
Once the car is clean, dry, and shiny, apply a layer or two of Meguiar's Gold Class Carnauba Wax. This premium carnauba wax has special polymers that bond to your paint creating shine and protection.
Now, stand back and enjoy the shine.
Meguiar's G3400 Brilliant Solutions Wheel Polishing Kit
Meguiar's Dynacone™ Polisher is the backbone of this Meguiar's Wheel Polishing Kit. Used with a drill, the Dynacone Polisher with Meguiar's All Metal Polish make it fast and easy to polish wheels and other metals. You will get a mirror-like shine in minutes with this combination. Use Meguiar's Wheel Polishing Kit on all un-coated, polished, or chrome metals.
The kit includes:
* 1 - Meguiar's Dynacone Drill Mounted Polishing tool
* 1 - 4oz Meguiar's All Metal Polish
* 1 - 4oz Meguiar's Foam Pad Cleaner
The patented ergonomically design of Meguiar's Dynacone Polisher easily polishes all wheel areas. The patented diamond shape gets behind the spokes and into tricky wheel areas. The built-in arbor sleeve offers more control and tool support while in use. The rugged Dynacone Polisher won't rip or tear like some other tools..
Meguiar's All Metal Polish can quickly remove oxidation and defects without scratching. The metal polish has polishing oils that help finish the surface to a mirror-like shine. Use Meguiar's Wheel Polishing Kit on cast aluminum, magnesium, billet alloy, chrome, stainless steel, brass, and copper.
When you are all done shining up your wheels use Meguiar's Foam Pad Cleaner. Cleaning your Dynacone Polisher after each use will give you years of operation.
Meguiar's G2016 Convertible Top Cleaner
Keep your convertible top clean and looking new using Meguiar's Convertible Top Cleaner. It doesn't matter if your convertible top is cloth or vinyl, Meguiar's Convertible Top Cleaner will penetrate and clean even the toughest stains, and it is specially formulated to be safe and effective on all convertible top materials.
Meguiar's Convertible Top Cleaner is easy to use and keeps your top looking like new. Simply rinse the entire top with water. Spray Meguiar's Convertible Top Cleaner liberally over an area and gently agitate with a soft scrub brush or wash mitt. Then rinse away the dirt. It's that easy.
Meguiar's G14716 Ultimate Protectant Spray 16oz
Meguiar's Ultimate Protectant provides shine and protection to all your interior and exterior vinyl, rubber and plastic. Not only do you get a long lasting shine, but Meguiar's Ultimate Protectant also provides long lasting UV protection as well.
You can use Meguiar's Ultimate Protectant on dashboards, vinyl panels, plastic inserts, exterior trim, door seals, tires, etc. Use it anywhere you want superior UV protection and a shine that significantly outlasts conventional protectants.
Meguiar's Ultimate Protectant looks great on areas that are already in good condition, but it can also bring back faded, neglected materials as well. These areas may need more than one application to bring back the original luster. This is not for use on glass, paint, tire tread, leather, motorcycle or bicycle seats and pedals. Basically don't use it on surfaces you where you don't want a slick or glossy finish.
Meguiar's G14816 Engine Cleaner 16oz
Trying to decide how to clean your engine? Should you use an acid to cut the grease and run the risk of damaging hoses and wires, or use an all-purpose cleaner that takes a lot of scrubbing and busted knuckles to get your engine almost worth showing off? Just use Meguiar's Engine Cleaner and don't worry about either of those problems.
Meguiar's Engine Cleaner is safe on your engine parts and tough on grease and grime. No worries about using it on plastics and rubber found around your engine. Meguiar's Engine Cleaner uses a biodegradable formula that is quick and easy to use. It penetrates and cleans even the hardest to reach areas. Just be sure to cover and avoid sensitive electronics.
In most cases you don't need to scrub, but for heavier grease & grime, after letting Meguiar's Engine Cleaner to penetrate 2 to 3 minutes, you may need a brush. Rinse the engine thoroughly with water before allowing the cleaner to dry. Quickly rinse any overspray from adjacent painted body panels.
Meguiar's Engine Cleaner also works great for cleaning wheel wells. Simply spray it into wheel wells. Allow it to penetrate up to a minute, and rinse off with a hose.
Meguiar's G15415 Endurance Tire Dressing 15oz (Aerosol)
Meguiar's Endurance Tire Shine is even easier to use now that it's in a spray. You still get the same long lasting, high gloss shine but now it's even easier to use. The advanced formula of Meguiar's Endurance Tire Shine gives your tires a rich, dark, high gloss shine for weeks, even through washing and rain.
Overspray is eliminated with Meguiar's Endurance Tire Shine quick-dry formula. It also reduces the chance of runs, drips, and slinging. Apply it with an applicator or directly spray directly on the tire.
Meguiar's Endurance Tire Shine has an advanced tire protectant technology that leaves a high gloss shine and protects your tires from UV damage and browning. It uses advanced macropolymers and copolymers that have made Meguiar's Endurance Tire Shine the enthusiast's favorite high gloss tire shine.
Meguiar's G15524 Endurance Tire Dressing Spray 24oz
Meguiar's G18211 Ultimate Paste Wax
Here is Meguiar's most advanced paste wax ever! Meguiar's Ultimate Paste Wax isn't like any other paste wax you've ever used. It is a pure synthetic polymer paste wax. It goes on effortlessly, and the appearance and durability is unlike any other paste wax.
Meguiar's incorporated it's hydrophobic polymer technology into this wax so water beads and rolls right off. No worries about water marks or stains after a rain with Meguiar's Ultimate Paste Wax.
Meguiar's sophisticated ThinFilm technology makes Ultimate Paste Wax easy to apply and remove. It can even be applied in full sunlight. Either way, you get maximum protection, durability, color depth and reflectivity on glossy paints and clear coats with Meguiar's Ultimate Paste Wax.
Your package includes a soft foam applicator pad to insure smooth application, and a Meguiar's Premium Shine Microfiber Towel to quickly capture and remove the wax residue.
Meguiar's G18216 Ultimate Liquid Wax 16oz
Meguiar's Ultimate Liquid Wax is Meguiar's most advanced wax ever! It amplifies reflections for incredible depth and mirror-like shine. It uses cross-linking synthetic polymers to form a long-lasting protective barrier.
Meguiar's incorporated it's hydrophobic polymer technology into this wax so water beads and rolls right off. No worries about water marks or stains after a rain with Meguiar's Ultimate Liquid Wax.
Meguiar's sophisticated ThinFilm technology makes Ultimate Liquid Wax easy to apply and remove. It can even be applied in full sunlight. Either way, you get maximum protection, durability, color depth and reflectivity on glossy paints and clear coats with Meguiar's Ultimate Liquid Wax.
Meguiar's G18516 Gold Class Leather & Vinyl Cleaner 16oz
If you are looking for a great leather and vinyl cleaner, look no further than Meguiar's Gold Class Leather & Vinyl Cleaner. You get superior cleaning for all forms of leather and vinyl surfaces. Meguiar's Leather & Vinyl Cleaner removes tough grime, embedded oils, and water based stains.
For general cleaning and maintenance, you can't beat the ease of Meguiar's Leather & Vinyl Cleaner. This lifts surface dirt and grime using a clean microfiber towel or applicator without using harsh chemicals that can strip leather's natural oils. Meguiar's Leather & Vinyl Cleaner uses a formula that will remove stains and provide a revitalized appearance to leather & vinyl surfaces.
Meguiar's G18616 Gold Class Leather Conditioner 16oz
Meguiar's Gold Class Leather Conditioner uses natural conditioning oils to maintain new leather, or revitalize neglected leather surfaces. Aloe and conditioning moisturizers soften and protect your leather leaving behind the natural look and feel of the leather. No powder or unwanted white residue is left behind when you use Meguiar's Leather Conditioner.
Use Meguiar's Leather Conditioner on your car's leather to protect it from UV rays to keep the leather looking like-new. With regular use, Meguiar's Leather Conditioner will keep all your leather surfaces soft and natural looking while preventing aging and fading.
Remember these great products from Meguiar's can be found at ProperAutoCare.com, your Car Care Friends!
The kit includes:
The kit includes:
The kit includes:
The kit includes:
Angelo...Your Car Care Friend
Email me at Angelo.g@properautocare.com
Toll Free 1-800-628-7596
Become a PAC Fan on our Facebook Fan Page
PAC's Twitter Page
Former Vendor
Remember folks these are the new products from Meguiar's for 2011, get them at the great PAC price!
Angelo ….Your Car Care Friend
The Most Talk About Sealant In the World Blackfire Wet Diamond
