Water spots in the paint
My car usually gets a wash every couple of weeks but the car sat for about two weeks with some dirty hard water spots on the trunk of the car from a sprinkler system that hit the car in an apartment complex.
Well for the most part the water spots came out when I washed it but if you look real hard at the right angle, you can still see the edge or ring of each water spot. I attempted to use a Meguiars compound product which I applied and buffed by hand. The spots lightened up and the surface is smooth as glass, but the edge of the water spots are still visible if you look hard enough.
Anyone have any suggestions?
Porter Cable 7424 with Orange or White Pad, light cutting compound, then orange pad with finishing glaze, wax, wipe, enjoy. Go on Youtube and search to see in action.
Adog!
Adog!
St. Jude Donor '09-'10, '14
Good luck if they're set in. You may try using white vinegar. It'll work as long as they aren't embedded really hard. If vinegar doesn't do it nothing will.
It will also take your wax off so you'll have to rewax, but it won't hurt your paint. Use vinegar also to get spots off your windows if and when you get them.
mine is embedded, from the PO, so hard I can't get them out no matter what I do. They only show up like yours, in certain light or certain angles, but they drive me bonkers because I know they're there.
I even rubbed them down with paint thinner a couple weeks ago. it helped a bunch but they're still there.
Good luck, (you can search here and you will find using vinegar is a common cure)
Try Turtle Wax Ice clear liquid polish.
If your car is black, try Turtle wax Black Box polish, has a black pigment. 3 step process:
cleaner, wax, detail spray.
Porter Cable 7424 saves a lot of work.
No, I don't work for Turtle Wax!
I tried the liquid polish before the compound with no luck. I will try the vinegar next. It's frustrating that it only took a week or two before the water spots did permanent damage to the paint.
Clay bar your vette, rubbing compound, then wax cleaner, then wax. That is what i did to get rid of hard water spots on my black vette. Not to mention a lot of elbo grease, you get a new meaning to the term "wax on / wax off"... Enjoy the ride.
Location: ALL governments are legalized mobsters, so doesn't matter where I live :(
Please stay away from anything that has the name "turtle wax." Most of their products are subpar and a waste of money. For your case I highly recommend purchasing a "fine cut cleaner." Mcguires makes a good one, as does 3M. The 3M comes in a small bottle and can be used either by hand or with an orbital polisher. I strongly recommend polishing by hand first before you resort to an orbital polisher.
Step 1
Use detergent dishwasher soap on the affected area. The detergent will remove any wax and oil residue as you want the area to be completely bare.
Step 2
Use a microfiber cloth and either the 3M fine cut cleaner or another TOP name brand...none of that Pep boys stuff.
Step 3
Depending on how severe the water spot is you may have to go over it a couple of times, but it should get the spot out. If it's really bad, then you may need a medium cleaner or use an orbital polisher, but judging by what you explained the fine cut should work.
Step 4
Apply polish, then wax, (preferably) or just wax to your affected area to protect it again...DONE!
good luck
Good luck
Step 1
Step 2
Step 3
Step 4
good luck
Good luck
