HD Poxy - The Original
Former Vendor
HD POXY along with HD UNO were the 2 products that changed my professional life as a detailer. After the first detail, I was hooked. I couldn't believe how much simpler and easier it was while you use a lot less too! Using only 2 products, yet the gloss/shine was noticeably better. That was August of 2009. I have been using these 2 products ever since.
Crafted from Mined Fossilized Montan Wax
Higher Temp-Resistance than Carnauba!
http://www.autopia-store.org/HD-Poxy.html?a_aid=8013
HD Poxy®, is a hybrid paint sealant/wax that has been designed to bond to the painted surface for protection and a long lasting durable shine. Its montan wax properties wilHD Poxy®, is a hybrid paint sealant/wax that has been designed to bond to the painted surface for protection and a long lasting durable shine. Its montan wax properties will darken the appearance and create depth for the ultimate wet-look shine, works exceptionally well on all colors including black and dark color paints. Unlike any wax available HD Poxy® will give you a deep, glossy finish while protecting against the natural effects of Mother Nature, bird droppings, acid rain, hard water deposits and many other adverse paint challenges.
Crafted from Mined Fossilized Montan Wax HD POXY® is the highest heat resistant wax on the market. Carnauba Wax melts at 187°F, whereas Montan Wax melting point is 203°F.l darken the appearance and create depth for the ultimate wet-look shine, works exceptionally well on all colors including black and dark color paints. Unlike any wax available HD Poxy® will give you a deep, glossy finish while protecting against the natural effects of Mother Nature, bird droppings, acid rain, hard water deposits and many other adverse paint challenges.
Former Vendor
Nothing but HD UNO & HD POXY
P1010692 by thomasdekany, on Flickr
P1010697 by thomasdekany, on Flickr
Former Vendor
Like most high end detailers, I have used menzerna for years.
But not since I first tried HD UNO. Now there is nothing wrong with them, they will provide great finish for sure.
1 - THE biggest difference for me is the deep dark finish I get with the HD polishes. That alone sold me after the first panel I corrected. Menzerna is more shiny (to me eyes)
2 - I don't care for dusting at at all - I actually hate polishing dust. the HD line doesn dust. Can't say that for menzerna
3 - HD polishes do not hide. Can't say that for menzerna
4 - easy to use, humidity doesn't effect it. Menzerna is finicky like that.
5 - Simpler. With the exception of flat, non metallic paint, you can just use HD UNO. All you do is change pads, from wool cutting to soft finishing pads. 1 product does it all. UNO is that good of a product. It is simple. How many bottles of polish do I need to purchase to get the job done? Right?
6 - HD polishes have a long working time.
7 - The amount of product that you need is minimal, including the wax HD POXY. Saves $$$ (I know some don't care about that)
You should see my collection of detailing items when I do mobile work. 1 big bin of towels, 1 big bin of pads, and 4 32oz of bottles.
HD UNO, HD SPEED, HD POLISH and HD POXY.
In the past I used to have 1 full bin of polishes, waxes, sealants etc...
St. Jude Donor '09
Since you asked - thanks BTW!
Does the polish break down the longer you work it......?
And have you noticed any filler products in HD disappearing after a few washes.....?
Former Vendor
Step #3
No filling, I wouldn't use HD if it filled. That is a big reason why I don't use Menzerna.
Non diminishing, you can work it longer if needed like with deeper scratches.
Former Vendor
