Hard water spots! ugh....
Well I left my car at my uncles over night... Car got nailed by hard water from sprinklers. I didn't think anything of it and now 3 days later... I washed the car and they will not come out. I washed it, tried the 50/50 water/vinegar deal... That didn't work... I'm so pissed! Anyone have some suggestions???
Location: Ponte Vedra Beach / London State: Dazed and confused
Removing ‘Water spots’
Always start by using the least abrasive product first
1. Use a paint surface cleaner (Z-PC Fusion Dual Action Paint Cleaner or Duragloss 501)
2. Try to dissolve the alkaline-based, surface/etched mineral water deposits try one or more of the following;
a) Use a 2:1 or stronger solution of distilled water/distilled white vinegar (Acetic acid)
b) Try a 2:1 solution of distilled water/Isopropyl Alcohol (adjust ratio as required)
c) Or equal parts distilled water/distilled white vinegar/Isopropyl alcohol.
3. Clean the effected surface with Klasse All-In-One or Zaino Z-PC Fusion Dual Action Paint Cleaner
4. Use detailing clay to remove any `hard' surface granules
5. Use a machine polish (Optimum Polish, Optimum Compound) and a cutting (LC White, Orange or Yellow) foam pad (speed # 4- 5.0) to level the paint surface
6. Use the least aggressive polish/foam pad first, if this doesn’t remove the problem step-up to a more aggressive polish / foam pad set-up
7. Wet-sand with 2000, 2500 or 3000 grit finishing paper
Former Vendor
The product is made for situations like your. Easy to use and it removes water spots with ease.
http://www.3dproducts.com/Eraser-Wat...tml?a_aid=8013
Here is the store locator page. If you have any other questions, just ask.
http://www.3dproducts.com/blog/locations/
eraser by thomasdekany, on Flickr
Morning c6speedjon! i am not sure how far you are from any of the 3D stores, but you should pick up a bottle of this Water spot remover.
Former Vendor
Ok thanks... I think I'll try this... Anyone had success using this? I'm very close to your Montclair location (about 15 min away) I'll probably buy this and try it in on my car in your parking lot! SO IT BETTER WORK! Haha! Jk! Really hoping this will work... I do not want to have to take a buffer to my car... Because I do not have one and really don't feel like spending a ton of money to have a detail shop remove this. This product will remove HARD water stains correct? Remember these have been sitting baking in the Cali sun for 3 days...
"Spread a small amount on cool glass or paint of the car. Rub in with a towel and rinse off. For extreme conditions repeat process using a Scrub Sponge. Although “3D Eraser Gel” is a mild based acidic product, do not leave it on any surface for more than 1 MINUTE. Longer periods might etch glass. To neutralize, use 3D’s Pink Car Soap. USE GLOVES and PROTECTIVE EYEWARE."
Does this mean I HAVE to buy your soap too? Will the car wash soap I have work as well? Maybe even hitting it with quick detailed after rinsing it?
Former Vendor
Former Vendor
Most waterspots need to be removed quickly with cleaners like those from Duragloss and Chemical Guys. If you dont remove them quickly they can etch the surface and require polishing and/or wet-sanding to remove. Some also suggest using white vinegar on recent spots and then rewashing
Try to keep a good wax or sealant on your paint, wash as often as possible, and remove anything like waterspots, egg, birdie doo-doo off as soon as possible.
Former Vendor
Don't worry, the product you bought (if you bought it) is a very high quality product, designed by a very clever chemist. Not a relabeled third party made product.
Former Vendor
Update...
I rewashed the car tonight and waxed it with mothers carnuba wax and it seems to be mostly gone... Gonna rewash it again this week and put another coat of wax on it and see how it looks... Gotta love how the car looks and feels after a fresh coat of wax!
Former Vendor
most waxes sold at retail have at least a light cleaner or polishing agent in them, likely it helped. If you find a stubborn area try and dedicated polish or paint cleanser and you should be good to go. Glad to hear it all worked out well.
