Got my Opti-Coat 2.0 from Auto Geek, and...
Washed my silver 2009 Hummer H3 with Dawn detergent.
Claybarred then wiped down with 50/50 rubbing alcohol/water combo.
Went to work with the Opti-Coat. Did the windows, paint and plastic trim (cadding).
Last year I put gTechniq C4 on the cadding. Despite the exposure to the hot sun, it still looked perfect but I still put the Opti over it.
This stuff is ridiculous! Goes on with almost zero effort! Wiped with very little pressure about one minute later and was done!
Did one panel at a time. Used a microfiber towel to wipe down the Opti after putting it on. Threw the microfiber towel away as it seemed to have gotten stiff from the Opti.
Hummer looks PHENOMENAL! Unbelievable! Stunning! Incredible!
The surface is slicker than the Ziano's, Adams, and all the other sealants I have used over the years.
Now the best part....I live in Phoenix where it is very, very dry and dusty. I live very close to the open desert so my cars tend to get extremely dusty after I wax them. The Opti has been on for a week now and there is not one speck of dust on it! I am stunned! Woody!
I went and ordered another container of Opti-Coat from Auto Geek already. Gonna do my Ford Expedition next. If it goes as well as the Hummer, I am going to order another container and do the C6. Will I do my Ferrari 360 is the real question right now! I am gonna wait and see!!!!
BTW.....Auto Geek threw in a really nice microfiber towel at no cost. Too nice to use with the Opti. I used an old microfiber for the Opti!
Former Vendor
Opti-coat 2.0 is a coating (not really a wax or sealant) and is amazing in that it almost seems to add an additional layer of semi-permanent protection for easily a year or more. The cool thing is it actually repels dirt and dust to a degree no other product offers. The thing that takes a bit of getting use to is the way water slides off the surface and doesnt really bead as a common wax does.
I can offer I used the original professional product (Opti-gard) first on my past daily driver and for over 13 months it did its job. I have no doubt the new owner wonders what in the heck is on this finish.
Thanks for the review, and purchase, and hope to see updates as time passes and you use it on more rides. Just remember, you might get a little lost or bored with no need to refinish the cars every so often.
Former Vendor
Former Vendor
Opti-coat 2.0 almost seems to add an additional layer of semi-permanent protection for easily a year or more.
For the sake of clarification, Opti-Coat IS a PERMANANT LAYER that DOES ADD an additional (measurable) layer to the surface. This coating doesn't wear away and lasts as long as your paint.
Besides being one the few professional detailers registered to apply this coating, I've also been involved with quite a bit of testing with Optimum.
Here's a monumental thread I created demonstrating the durability of the coating during a 2 year testing period. Keep in mind that I washed this vehicle with a strong dose of Dawn dish detergent on a weekly basis and the coating was still like new after 2 years:
http://www.autopia.org/forum/car-det...st-review.html
Great info David!
I applied Opti 2.0 to my Hummer H3 and Ford Expedition. It was really hard to see where I had applied it and where I missed. In other words, it goes on so thin it is difficult to tell if it went on correctly. Advice?
Former Vendor
Let me know if this makes sense and/or you need further assistance.
I did a very thorough wipe down with 50% and 50% Rubbing Alcohol.
I beleive it covered well. I kept checking that the product was on the applicator by wiping a small section of glass and seeing if the product was left behind on the glass. It was wet everytime I tried it.
I also used the blue paper towel over the foam applicator trick like Opti has on You Tube to keep all the product from soeaking into the foam.
I used one syringe per vehicle so I assume I wasn't applying it too thuin????
How mucg should one syringe cover?
Thanks for your help!
I wiped each panel down with a microfiber towel within minutes of application. I haven't seen any "rain-bowing" or hologram effects so it must have applied it properly since I used an entire syringe per vehicle???
Former Vendor
Perhaps you should visit our forum at www.autogeekonline.net and look at several of the posts on Opticoat and Optiguard (the professional version) as reference.
Here is one on application for a Camry: http://www.autogeekonline.net/forum/...made-easy.html
Yes, I wiped it down very lightly to take out any uneven spots. I applied it just like the Opti video on You Tube shows. Here it is:
http://www.youtube.com/watch?v=Yyo_-UA8yM4
I did it right didn't I so long as I follwoed this video?
I sued one syringe on my Hummer H3 which included all the glass and plastic cadding.
I used another on my Expedition.
Does this seem like too much?
Does it hurt to put a second coat on?
What is the shelf life for the unused product? I'd like to "treat" 8 summer wheels now (I'm indoors and bored already) and do a car or two next spring when it warms up.
I get the impression with the syringe container that you might want to use it up quickly after opening?
Former Vendor
If you want two seperate products, Gtechnic makes a Wheel Armor product specifically for wheels, and its a ceramic based coating system. I recently used it on my uncoated Iforged Wheels. (just another option)
Former Vendor
You can reapply an additional layer within 30 days of the initial one so feel free to add another if you'd like to build things up. Just wait atleast an hour for the initial coating to cross-link.
As for stroring your coating, what harms the coating is air, so make sure that the storage tip is firming tightened and that you store your tube in stable temps (indoors). I have syringes that are 3 years old that are stll fine.
