Megiuars NXT
Megiuars NXT
Does this wax dry white or clear?
Concerned about residue on black parts and in cracks and crevices.
Any trip or tricks to avoid or remove residue if an issue?
Dave
Dave
I use NXT 2.0 (which has been somewhat superseded, I think, by Meguiar's Ultimate Liquid Wax), and while it isn't nearly as bad as some waxes and products that I've used as far as leaving residue on plastic, it still does. If you do accidentally get some on a piece of plastic trim, it should wipe right off with a towel as long as you don't let it sit on there. You will get some white residue if you lay it on too thick, but it's not a problem if you apply it properly.
